Aluminum Gas Tank Leak
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Aluminum Gas Tank Leak
    There's an aircraft fuel tank sealant known under various names such as Chem Seal & Pro Seal. It's a 2 part rubbery putty that comes in different colors & thick & thin consistancies. It's obviously made for use with aluminum & is used on aircraft for more than just sealing fuel tanks. I call it a flexible JB Weld 'cause it's pretty versatile. There are also sloshing sealers available. Here's a link to a few.
    Pilot Supplies, Avionics, and Homebuilt Aircraft Parts from Aircraft Spruce and Specialty Co.
    Tulsa, OK
    1,725
    I've bought that low temp rod before at the fair.. not used it yet. The guy demo'd it by filling in a hole in a pop can, so it does work on thin stuff. Not cheap if you have to buy a bundle of it though.
    A bar of soap rubbed on a gas leak will seal and last quite a while, unless it gets washed off.
