!st day new used max IV need chain and other info
Results 1 to 2 of 2
Thread: !st day new used max IV need chain and other info
    1st day used max IV need chain and other info
    Got a used max IV yesterday.Cleaned it up sprayed some lube on the chains .
    I took it out for a couple cruises .
    I took my wife out and heard a pop couldn't turn left. The chain is off the left rear sprocket.
    On closer inspection it has a broken middle axle bolt and 2 teeth broken on idler gear. I want to replace all of the chains what is the best source for chains and how much chain do I need to buy to replace all of the chains?
    Is there a repair manual available for Max IV, best place to get a belt?
    Any input would be greatly appreciated.
    Thanks Scott
    Dec 2007
    eden nc
    1,484
    scott rec uses tsubsaki chain and rec will have yout spocket . jest talk to jay or heydan . they can hook you up . great guys up there . robbie
