attex reverse
Results 1 to 5 of 5
Thread: attex reverse
    attex reverse
    hello im john.has anyone use the parts from a snowmobile that had reverse.use the axel with reverse thanks
    Northern VA
    2,766
    I'm not sure how you'd get a snowmobile transmission to work on the 208 John, but there are people on this site- myself included, that would probably trade you a reversing transmission even up for the original straight shaft. The reverse and non-reverse ATV manufacturing transmissions both fit on the same base.
    Good Luck with the 208 project.
    attex
    my tranny that in the 208 might be going in the scrambler
    attex
    ive seen a small dunebuggy with all the snowmobile parts with reverse,and had an idea,like in the middle of my tranny just put the snowmobile tranny for reverse
    Buffalo, NY area
    2,968
    That's basically what the reversing version of your transmission is. It's a planetary gear setup that doesn't really increase the overall size of the trans. as a whole, and it's a "known quantity" when compared with fabricating a reversing setup to fit your existing machine. There are plenty of the correct ATV Manufacturing Co. reversing transmissions out there that will bolt directly into your machine with absolutely no modifications.. Sign me up on the list of people who will trade you a reversing trans. for your "forward only"...
    ~m
