carb cleaner and wd-40 don't burn all that great. get a can of starting fluid or brake clean. even with that it won't run long. it will either burn it all at once, or you'll flood the engine if you keep trying to spray it. i would spend the cash on a carb rebuild. the carb delivers the right ratio of air and fuel... you can't really replicate that with a spray can, and can do dammage to the engine if you do it too much
