I hope the honda24 makes my maxll wake up a little,The 14 briggs will do OK with one person.There is nothing worse than getting in a tight situation and running out of power.Your's sounds like it is doing pretty good,Thats the way i like to roll.
Sounds like a plan. I think the 24 Honda will be great. Does it have a 1" straight shaft for your clutch?
I started to mention the plug clearance, I thought it might be ok with the head not milled. Depends on how the ground electrode indexes when you screw it in. Hasn't happened to me with the .040 stock gaskets but it's a common problem. I used the conduit also. Hope you didn't breath the galvanized fumes.. happy to hear your satisfied with the power. Drill the main jet if you havn't, it's only a couple thousandths, but adds power and keeps combustion temps down, not overly rich at all.
I do plan on drilling the jet, and also moving the breather tube. I'm getting a little oil in the filter area especially since using the Briggs 5W30 Syn oil.
What kind of speeds do you get on your machine? I need to get used to the new power. I find myself trying to slow down way to much. You pull the throttle and launch like a rocket. I was suprised how much the exhaust made a difference over the gutted stock. It is very easy to hit over 5,000rpm, might research possibility of a rev limiter.
Rut
Have never checked the speed, it's low geared so not that fast. Non synthetic is recommended for break in, might be your oil problem, syn is too slick for ring seating. What did you do for a bore finish.
Roger,
I used the stock pre-broken in rings with the same pistons in the same hole. Did not hone or anything. I do not have any oil fouling or wet oily sparkplugs. My piston rings are sealed fine. Did this because I have a new low time engine.
The only part not traditionaly broke in would be the rod bearings.
The oil is coming from the breather, it was doing this a little before the mods with the 30W oil. Might be a little overfull. I put in 48 ounces.
Then moving the breather will take care of it.
The exhaust does make a huge difference. That's why mine is not quiet. Any attempt to muffle the thing takes away upper end power.
I really enjoyed building the exhaust. Probably going to make some more or at least one more that is not so loud. It will be neat to see if bottom end is lessoned with a muffled exhaust.
BTW: I did run 5w30 Pensoil in the engine for an hour before switching to the synthetic.
Exhaust theory, I liked this page.
RB Racing LSR 2-1 Exhaust Technology
