Looking good and getting closer!!! Cant wait to see it with those aluminum rims.
It's looking great so far, JP!
lookin good Jeff, and your way ahead of where you were last year!
Looking great Jeff!
Wow Jeff, you are really moving along!!! Looks great. Those arent the wheels your running though right? I though you where running some aluminum bling bling wheels?
Im still working on my body. I hate sanding so badly. Once thats done the mechanical stuff is a breeze.
Thanks for the kind words everyone. And Brian, you're right, I feel like I'm certainly pushing forward much more than last year. Its still going to be close though.
Larry, I have a set of 6 polished aluminum wheels, but I still have to switch the tires over to them and make some adapter plates. I might not have time, but if I do I'll certainly run the aluminum bling rims. If you want to save yourself TONS of time, use acetone. I did my entire lower body in less than half a day. Just take a clean white rag and get a part of it wet. Then rub it in circles like you're waxing the body. The oxidation comes right off! Make sure you keep flipping the rag over so you have a clean white part of it, and make sure you do it in the shade. Then I take some 500 grit sand paper and wet sand it. Then wet sand it with 1000 grit, wax it, and it will shine so bright!
And Don, I was just waiting for someone to make the 4 wheeler comment.
That is what I did on my lil little truck but it was painted so I put a sanding disk in the drill. Smaller sized cant remember exactly but something like 2.5-3". I rigged the garden hose to run like a coolant line on the drill by putting an adapter on it cutting it down to 1/4" line then tapped it to the drill with it running down to the chuck. The water wasnt for a wet sand but to keep the abs from melting onto the sand paper. Then I acetoned it. I believe the acetone melts the abs and then it filles in all the scratches. I never messed with sanding afterwards. The headlight, inner seat area and the rear inner part where the ribs are, are the hard part for sanding. I found the best way to get the hard to reach spots(corners) is to scratch away with the leatherman blade. The Gerber blade isnt arced and dont work as well. I hate gerber. That method works real good if you have paint on the machine. My 208tt is so oxidized Im doing the same thing with the drill. Acetone is awesome. I told amphiman about it and he used it on the hawk hi torq. I will try the lower body without sanding. Thanks for tip!
Sorry to hack you thread. I started to ramble.
