What would you do???
Results 11 to 20 of 26
Thread: What would you do???
    Dec 2008
    Lake Charles, LA
    174
    Thanks for the video. I could not hear any metal on metal. Like others have said check the spark plug for a spark, along with tight, clean connectons on wiring going to the plug. You said the plug was wet when you pulled it so it is getting fuel, now you just need a spark! Keep posting what your doing and we can all work through it.
    Meadville, Pa
    3,286
    no spark
    Alright I gave her the old hillbilly spark test (screwdriver in the wire) and could not get any spark off of anything I touched while cranking it over.
    Dec 2008
    Lake Charles, LA
    174
    Quote Originally Posted by amphibious drew View Post
    No the hillbilly test is to grab hold of the spark plug at the tip and try to start it
    Meadville, Pa
    3,286
    Get me a few beers and I'll give that a shot too.
    Not sure how serious you are roadtorque, but after a few beers I've been known to try most anything while trying to fix up a project.
  5. #15
    Jan 2008
    Vicksburg, Michigan
    3,507
    Hey Drew,
    Well if it was the key, it should still spark, just not at the right time as long as the flywheel is spinning which is is for the starter to spin the motor over. So I would go for maybe a wiring issue. First thing I would do from here is locate the kill switch wire. Usually a black one coming from the coil. If that shorts out on anything it will kill the spark. So disconnect it and try again for spark. Hopefull this is something as simple as a wire gone wrong somewhere.
    Is it still making the noise you heard. I dont hear anything. If there was something maybe the coil came loose and hit the flywheel or something.
  6. #16
    Dec 2008
    Lake Charles, LA
    174
    I'm not serious, it will give you a zap if you try it. Doesnt feel to good
  7. #17
    Meadville, Pa
    3,286
    black wire test
    Larry,
    Thanks, tried the wire test but it still didn't start. I think the noise was just the clutch disengaging when I gave up trying to crank it over.
  8. #18
    Jan 2008
    Vicksburg, Michigan
    3,507
    Hey Drew
    I did some searching and here is a pdf manual on your engine. chapter 8 page 47 starts ignition system. Maybe something there can help you. I would bookmark that as I just did.
    8-18hp cast iron 4 cycle tecumseh engines
    good luck
  9. #19
    Meadville, Pa
    3,286
    great help
    Larry, that should be a tremendous help. Thank you. I saved the book and will be doing a series of test after work tomorrow. I feel better keeping this one factory original. I feel confident I can at least diagnose the problem by the weekend and keep my wife from complaining about my expensive immobile toys.
  10. #20
    statesville, north carolina
    2,604
    if the wife complains too much, just get her one! my wife does more donuts in the yard now than i do as for immobile toys, that's bound to happen. i'm currently at 4 machines, and the last of them, the argo should be back running tomorrow after a 2 month stint in the shop... only a matter of time till the next one breaks and so the cycle continues
