Originally Posted by
Bw6
The New Argo HDi 8x8 Has The Following Features:
1. Apache Transmission: 2 Speed (Low/High), When Handlebar is moved to lock position (In Low Only) the tires will automatically counter-rotate. Steering effort is like power steering on your Automobile, effortless. Shifting from Low to High has a type of synchromesh, that will engage automatically when the rpm is correct. The 2 output shafts are positioned very low and extend out to the sides of the frame, where support bearings are located, from there, it's double 50 to the front shaft. This transmission is mounted in the frame very low and independent from the motor (31 hp efi).
It also has 2 hydraulic caliper/rotors located on the output shaft close to the transmission. This transmission 35% more efficient than a comparable Hydrostatic type. No more power loss when turning! This is a patented design. I am speculating that it must have some sort of Dual Planetary Gear set, that does the counter-rotating, how it is automatically initiated is a mystery to me.
2. It has hydraulically operated hand lever operated brakes (no adjustments required)
2. It has a new hood design that has a forward facing scoop, and small side screens. Under the scoop is 2 large screened ventilation areas. It also still maintains the standard side screens. I wonder if the scoop will along water to enter the engine compartment doing steep water entries?
3. The axles have been increased to 1 3/8", with a new triple sealed bearing mounted in a "special" 4 hole pattern to match existing Avengers to allow for future retro-fits. The bearing mount looks like cast iron. The bearing flange has one grease fitting that can be greased via a matching hole in the rim.
4. New water proof sealed switches, with room for expansion in the new panel.
5. Digital Tach
The rest of the 8x8 looks like stock Avenger EFI. The automatic counter-rotating feature is pretty slick, doing a perfect tight doughnut. They are available in limited numbers up to November/09. Price is in the $19,500 range I've heard. Speed are pretty much the same as the Avenger.
