Are the old Attex hubs wort anything? I was thinking of using them to make adapters for using golf cart rims but I dont want to cut up something that someone else could use.
Cave Trolls Rule!
Well I printed that template off of here and the 3 bolt hole line up. I guess the next thing I need to do is build a cutting adaptor for the torch to cut true circles and modify the template for a 4 bolt pattern and try it.
Cave Trolls Rule!
I made a 4 bolt template for Jeff, I just have to get it online. i will do so soon.
Mike
I got the template posted here: http://www.6x6world.com/forums/gener...-template.html
Thanks Mike!
I cant help but wonder if a guy could make a set of adaptors using both templates and be able to run 4 OR 5 lug rims on the same adaptor.
Cave Trolls Rule!
Not sure but at least a couple of the holes from the 4 and 5 pattern would probably be too close together or overlap. But anyways, you would have to remove and re-install the studs since the unused studs would prevent you from putting the rim on, and if you use bolts they won't quite center right, and are a @#%@$% pain in the butt to install a rim with anyways.
Attex Super Chief - Sold.
