how do i fix my hustler?
Page 3 of 11 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 110
Thread: how do i fix my hustler?
  1. #21
    Sep 2009
    Bryan, Texas
    748
    Well I went ahead and pulled the frame out of the tub. Just my luck the trans has had gear oil in for 10+ years, go figure. Where do I get parts for the t-20? Does the company still exist? If they do I'm only about an hour from Jonesboro so I could go there. I almost have everything to put it back together all thats left are the axle bearings some clean up and paint and now the trans.
    2010 Chevy Silverado 1500
    1974 Honda ATC 70
    1986 Honda ATC 250ES Big Red
    There is no Z in Diesel!!
  2. #22
    Give Recreatives a call they own the mfg of the t-20 and have all the parts.
    Contact Us - Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511
  3. #23
    Sep 2009
    Bryan, Texas
    748
    What's the best way to fix cracks in my tub. It's broke above one of the headlights from the bumper brackets, and there are some cracks and broke spots on the top. Silicone is not exactly a good substitute for solid abs. I've herd of plastic welding kits but they're kind of expensive. Is there a better way to fix it or should I just get a new tub and top...
    1974 Honda ATC 70
  4. #24
    Tub repair
    There is a stick that is melted on alum. boats to repair leaks that works pretty well; you might try Bass Pro Shop Or Cabela's Marine catalog to find the stuff.
  5. #25
    Sep 2009
    Bryan, Texas
    748
    Ok I fixed the tub crack with quicksteel(should of thought about that earlier lol). Can yall post some pics of homemade exhaust systems for the k341 engine setup? The old muffler is rusted away and i need somthing to get the exhaust out of the tub. I also need a throttle lever, the only one I can find is from a Max dealer and its $35. Is this the cheapest I can get one? The only other thing is a new gas cap (twist on not threaded), and the only one of these I found is from Richard's Relics.
    1974 Honda ATC 70
  6. #26
    Mar 2009
    Alabama the Beautiful
    888
    Hi stonewall,You should be able to get the gas cap from an auto parts store,Old chevy and ford trucks with the gas tanks behind the seat had the same type gas caps.You may be able to use a bicycle brake cable if you can find one long enough.
  7. #27
    Sep 2009
    Bryan, Texas
    748
    If at all possible, I'd like to get the origional type of gas gap with the guage in it, I could probably find five or six gas caps that would fit it layin around our shop.....same with the throttle lever, I really want to keep it origional. Exhaust pics anyone?
    1974 Honda ATC 70
  8. #28
    Sep 2009
    Bryan, Texas
    748
    Ok I took some pictures to show yall how it coming along...it should run this weekend, Ive been havin some trouble with the starter for a few days and just now realized that with the rubber gromets on the engine mount, its not grounded (how did I miss this??????). I was wondering about Richard's relics...i seem to remember someone told me not to buy anything from him but he has some parts that I need and cant find anywhere else, plus he claims to have bought out the entire hustler corp stock...is this true? I need some hustler-specific parts that he has...what should I do? (NOTE: the first 3 pictures are from when I first brought the hustler home...the rest I took a couple days ago)
    1974 Honda ATC 70
  9. #29
    Sep 2009
    Bryan, Texas
    748
    (other 4 pics...) I used sprocket idlers instead of the stock plastic things there are some pics of the special brackets i made for the front ones out of 2 inch angle iron and some 1/2 inch nuts
    1974 Honda ATC 70
  10. #30
    Sep 2009
    Bryan, Texas
    748
    Wow, y'all weren't kiddin' when you said t-20 parts are expensive!! I just ordered bands, 1 drum, bearings and seals and it was over $800!!!! Thats more than I've spent on the entire project!! Now all I need are a few things from Richard and I'll be done.
    1974 Honda ATC 70
