artic cat 340 motor on an attex?
Results 1 to 10 of 17
Thread: artic cat 340 motor on an attex?
    Aug 2009
    Pittsburgh Pa
    87
    will this motor work on my attex? I can get a good deal on it just need to know before I buy
    You'll probably have to modify the mount. As far as power goes, I had a JLO 340 in my springer for a while and it did a pretty decent job pushing it along.
    Aug 2009
    Pittsburgh Pa
    87
    great the motor is in the sled now running and all just rebuilt. The problem I have is that I am missing a coil and rectifier on my attex so I should be able to swap it all in and be running correct??
    Jan 2008
    Vicksburg, Michigan
    3,507
    It should move it right along nicely.
    Aug 2009
    Pittsburgh Pa
    87
    its a 76 340 artic cat fan cooled motor. just talked to the guy gonna go pick it up at 4pm whole sled said there is something wrong though with the return gas line on it
    Aug 2009
    Pittsburgh Pa
    87
    i think the setup may be reversed the clutch on the sled is on the other side does that matter? if not how do i fix it
    Jan 2008
    Vicksburg, Michigan
    3,507
    Thumbs down
    Sweet, should be a cool project. Keep us updated. Get some before, during and after pictures to keep us all amused.
    Aug 2009
    Pittsburgh Pa
    87
    heres a pic of a 340 http://www.snowmobilelinks.com/Quad%20Plug.jpg
    how do i install it to be correct
    Jan 2008
    Vicksburg, Michigan
    3,507
    The carb should be in back and exhaust forward, which is backward from stock. I have not Idea if it will work or not but some singles cylinder engines can have the whole top end lifted up and turned around. I have no idea about that on your engine. Or you may have to run exhaust differently.
    Aug 2009
    Pittsburgh Pa
    87
    I would be ok with a different exhaust setup but if it were spun around wouldn't the tranny spin backwards??
