jlo 297 questions
Results 1 to 10 of 38
Thread: jlo 297 questions
    Aug 2009
    Pittsburgh Pa
    87
    jlo 297 questions
    I need to get a new coil what kind do i get?????
    Jan 2008
    Vicksburg, Michigan
    3,507
    Hello argo
    Do you have the stock jlo? I would find out what engine you have and search ebay or online for parts.
    Aug 2009
    Pittsburgh Pa
    87
    ok the guy before me had a car coil hooked up and it fried
    Aug 2009
    Pittsburgh Pa
    87
    ok just checked its the jlo 297 I am guessing when he put the car coil on he screwed it up and thats my problem But noew I need to get a coil and figure out wiring
    Aug 2009
    Pittsburgh Pa
    87
    what kind of coil?
    Will a car coil work on a jlo 297???
    Aug 2009
    Pittsburgh Pa
    87
    will a car coil work i am going to try to get this running right now
    Aug 2009
    Pittsburgh Pa
    87
    jlo 297 questions
    Well I pulled the carb off to see why its spitting fuel out the front of it and took it all apart. Inside where the needle is there is a pin hole that doesn't look stock all little burrs on it and stuff so i think thats the problem new carb and plug and she should fire up. I look in and the piston moves fine no other signs of somethin going on. Should I check anything else??
    Aug 2007
    near olean, ny
    1,083
    Smile Jlo
    Quote Originally Posted by ArgoH2 View Post
    disconnect the fuel line. turn it over with a clean spark plug. then try it with a little gas /oil mix, not much,should fire right up
    Aug 2009
    Pittsburgh Pa
    87
    I tried that earlier today still nothing lol this thing is killing me. The wiring doesn't look right either I have to figure that out he had wires cut laying all over.
    Aug 2009
    Pittsburgh Pa
    87
    forgot to add I got a new coil for it but how should it be wired up from the battery??? and what all needs to be grounded think that could also be problems
