Attex Restoration
Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 51
Thread: Attex Restoration
    Sep 2008
    woodland pa
    534
    bruiser
    thanks everybody for the great comments just wanted to show everybody what i started with and how it ended????????????? still have to put on a winch /wire in the hour meter i forgot and thinking about a split shifter that can lock together for 1 hand shifting/ Thanks again 6x6 world members i will repost the video they took it off because of the music
    North Huntingdon, Pennsylvania
    429
    Great video. That is an awesome machine!!!
    Quote Originally Posted by jeffery9076 View Post
    Try vimeo.com. I post all my videos there now. The upload process is easier, and they don't care about music.
    Northern VA
    2,766
    Great job on the video, and the machine! You had your work cut out for you.
    Sep 2008
    woodland pa
    534
    Bruiser upgrade
    Bruiser upgrade
    6 chain to 4 chain frame 6 chain was bent and want 4 chain
    1 1/4" max splined axle upgrade end of axles turned to 1" to fit stock inside attex bearings
    Frame drilled for new 62mm OD bearing flanges for the new axles
    New volar o ring chain blue 4 boxes 150 links each
  5. #15
    Sep 2013
    Caldwell, Idaho
    1,174
    Nice work
    I like those beefy axles
  6. #16
    Sep 2008
    woodland pa
    534
    bruiser upgrade
    Thanks Andyman
    they should hold up better than the 1" axles
    here is some work I got done today
  7. #17
    The blue side plates on the chain are a nice touch
  8. #18
    Sep 2008
    woodland pa
    534
    Thanks Mike It's Volar chain
    It comes in lots of colors some in different lengths depending on color
    TRY BF35 is a promo code coupon for black Friday 35 percent and cyber monday
    WS25 promo code 25 percent off
    530 O-Ring Motorcycle Chain with 108 Links
    I have had this chain on a Yamaha 125tt 3 years no problem
    Had it on a beefed Honda 1986 250x 2 years non oring no problem sold
    8 hours on bruiser 6 chain (t-20 to middle axle test 8 hours no adjustment)
  9. #19
    Sep 2008
    woodland pa
    534
    bruiser upgrade
    new inner bearings and flanges on the way from buffalo bearing $ 97
  10. #20
    Sep 2008
    woodland pa
    534
    tHIS IS THE 1ST RESTORATION
    THIS IS THE 1ST RESTORATION VIDEO OF BRUISER LAST FEW POSTS ARE THE UPGRADES I AM IN THE PROCESS OF DOING
    http://youtu.be/A78dklzX01c
