tire chains
+ Reply to Thread
Results 1 to 9 of 9
Thread: tire chains
  1. #1
    Join Date
    Aug 2010
    Location
    okanagan BC
    Posts
    9
    tire chains
    just curious if anyone has put chains on their tires for better traction in ice and snow....what were the results?
  2. #2
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    There are some existing threads that discuss them a little. You can use the search to find them until someone else chimes in. Here are a couple to get you started:
    http://www.6x6world.com/forums/argo-...-conquest.html
    http://www.6x6world.com/forums/tire-...ains-aatv.html
  3. #3
    Join Date
    Aug 2008
    Location
    Okanagan Similkameen BC, Canada
    Posts
    687
    I've got a stud gun and studs, just need to pick up the stud drill....buwa ha ha...
    just saying...
    MUSCATEER 6x6
    MUSCA TUR BOTA then eh?
    94 F350 4x4 7.3 IDI ZF 5sp
    Al "Camo pants"
  4. #4
    Join Date
    Aug 2010
    Location
    okanagan BC
    Posts
    9
    sorry mike, I did search for "tire chains", and "snow chains" but the threads that appeared just both happened to talk about tires, and chains, and snow, not tire chains. anyway, thanx for the links.
    Riot, the studded tires are a great idea, I guess that's why you need 2 sets of tires.
    The whole reason I brought it up is I can't really afford tracks, or even new tires at the moment, and last time I brought my machine up the mountain in the winter in less than a foot of snow it struggled for traction. This was on an unplowed dirt road. even a couple of inches of snow wasn't easy going. I happened to see a set of chains at a thrift store for a small car, and thought they may fit. If I see another set, I will pick them up.
  5. #5
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    I think what really helps with tracks in a lot of snow is the fact that your foot print is lowered by being spread out on a larger surface area, which gives you greater flotation. I don't think the chains will help in that regard but I think they will definitely give you better traction on smaller amounts of snow and ice like you described. If they are cheap enough, pick up a set and give it a try.
  6. #6
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    I have a friend with a MaxII and he runs chains on the back and says it helps out a lot in the winter, but as Mike stated doesn't help in the real deep snow but definitely aids in traction.
  7. #7
    Join Date
    Aug 2008
    Location
    Posts
    687
    in anything other than hard packed snow or very crusty snow these machines are not all that good without tracks from what I've seen
    Here dale
    http://www.6x6world.com/forums/parts...ale-600-a.html
    Some times you just have to suck it up and spend the $ to get where you want to be.
    MUSCATEER 6x6
    Al "Camo pants"
  8. #8
    Join Date
    Feb 2013
    Location
    shenendoah valley,va.
    Posts
    2,631
    ddale, i think you could modify a set of car snow chains to fit, then by some 3/16'' thick by 6'' or 8'' wide conveyor belting and weave it between the cross chains . then just overlap the belt ends and bolt with a couple of 1/4'' bolts with fender washers and nuts. the rubber belt will give the flotation in snow. the more cross chains,the better grab you will get, but not too many. i'm always messing with homemade track ideas. good luck. johnboy va.
  9. #9
    Join Date
    Aug 2010
    Location
    okanagan BC
    Posts
    9
    thanx for the replies guys. I will definitely be trying a set of chains...
    riot, I would happily spend 600 on a set of tracks if they were local. shipping from new York would cost far more than the sale price I'm sure. I have my eye on a PPT and a playcat for sale, and I'm pretty sure I can buy both for less than what the tracks with shipping would cost.
    johnboy, I will be making a set of tracks one day I think.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
