Tracks for 24" tires
+ Reply to Thread
Results 1 to 8 of 8
Thread: Tracks for 24" tires
  1. #1
    Join Date
    Jul 2014
    Location
    Mississippi
    Posts
    82
    Are there any tracks that will fit 24" runamucks?
  2. #2
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    402
    If you have a Avenger or HDI you can run Argo Supertracks, Argo Rubber, Adair, Escargo, or Chanel tracks. What machine are you running?
    From some of your other posts it looks like you might have a Max IV and if so you might have to do some modification to the tub to fit them on 24s.
  3. #3
    Join Date
    Jul 2014
    Location
    Mississippi
    Posts
    82
    I have a 96 Max IV, if i order the argo tracks for 24'' tires will they be the right length? I know ill have to reshape my tub for more clearance but i want to make sure they will be the right length.
  4. #4
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    402
    I think the wheel base of your max is very close to that of a 6x6 Frontier. Verify that and then you will be able to get the right amount of segments. I read where another member tried to put argo supertracks on his Max IV and had to trim the inside section of the track to clear the tub as well. Make sure you research this more before spending your hard earned cash.
    Quote Originally Posted by martin_andy25 View Post
  5. #5
    Join Date
    May 2010
    Location
    Fairbanks AK
    Posts
    1,457
    What tires do you have on your max now? With the 26 x12x12 teragrips you have to be able to place a 3/4" piece or material easily on top of the tires to have track clearance. This how I check a body for clearance and sag. With good clearance you can install tracks on 22" tires. I'm guessing but to get a set of super tracks on a IV you may need 4-5" spacers. I've tried to install trutrax on vehicles that didn't have clearance with 21" tires. Trutrax are very similar to plastic Argo tracks. With a really good body you can fit 22" Argo tires and Adair tracks with 2" spacers. Adair tracks are thicker than the plastic type.
  6. #6
    Join Date
    Oct 2010
    Location
    Wasilla, AK
    Posts
    923
    a channel grouser is 1/2" tall and will frequently allow machines that don't have enough clearance (unless they modify their tub or purchase an additional set of smaller tires which can be expensive) to easily run tracks.
    One of many reasons to consider it, depending on your application. Here's a pic of a Max 2 with 21x11x8 tires and 2.5" spacers. 18.5" track
    For instance, I've been able to run channel tracks on a conquest 8x8 with 24x10x8 tires.
    Tub clearance is a little different (to the inside) on a max but easy to work around.
  7. #7
    Join Date
    Jul 2014
    Location
    Mississippi
    Posts
    82
    i have 24x10x8 runamucks, can i fit those tracks on my tires on my max IV?
  8. #8
    Join Date
    Jul 2007
    Location
    Savannah, Georgia
    Posts
    1,821
    Martin, if you have the 24" Argo swimming tire and you are willing to put 2 1/2 to 3 inch spacers on your Max and you are willing to work with any problems you might encounter with body sag the channel tracks will work for you and they will actually gear your machine down a little. I don't know what engine you have in your machine but I would want at least 23 horse power. If you put in the time and effort I am sure that it would be a very potent combination and once you got everything sorted out it would be an unstoppable combination.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
