Clutch
Results 1 to 8 of 8
Thread: Clutch
    Clutch
    Hello-I just joined this sight and already have a question. Do most aatv use a torque convertor type centrifical clutch? My catagator uses a hydraulic type clutch where the clutch halves go together by hydraulic preasure from a foot pedal. I plan on upgrading to a Vangaurd engine and the appropriate clutch. I like the hydraulic set up but my machine sat for 24 years and the clutch cylinder is rusted beyond repair. I live in the Upper Penninsula of Michigan where the winters are long so I have a good winter project ahead of me. Thanks Packrat
    Pretty much every AATV, except for hydrostatic drive and some very old odd ball machines, use a torque convertor type centrifugal clutch. You can get a new one here:
    Search results for: 'recreatives' | MFG Supply
    If you're going with a Vanguard engine, get one with a 1" shaft, because the drive clutches for these are much cheaper than ones for a 1 1/8" shaft. A 23HP Vanguard can be bought with a 1" shaft, and that would be a nice motor to power your Catagator.
    Nov 2007
    East Bethel, Minnesota
    104
    hey packrat, what model is your catagator? I have one also, working on and trying to get some axles made. I have some info on them if you need any.
    Mike
    Thanks for the info. My catagator has a 24 hp Kohler now so a 23 hp vangaurd should work. Im looking toward a vangaurd because of availability. Is there an engine that would be better?
    Hey Mike- I'm not sure what model it is.; It is 8 wheel drive. It has the 24 hp Kohler engine. It also has the single wheels, not the duals. Also, it a 1968 model. I've had it for about 35 years but haven't started it for 24 years and the weather took its tool on the cosmedics. I know where there is one more but it has the dual wheel set up. I'm not sure if he will sell it or not. Packrat
    Nov 2007
    104
    do you have manuals? I can send you a file with info to your email.
    Hey Mike- That would be great. I did have the manuals and all of the paperwork that the original owner had but through the years must have got misplaced. If you can send them to johnson9600@gmail.com. that would be wonderful. I would be happy to pay you for your effort. I used this unit quit a bit for about 8-10 years and then parked it. My wife and I do a lot of off roading with friends and have a Honda 4 wheeler and a Arctic Cat Prowler. I also have a couple of 4x4 trucks and a jeep. I plan to build my '53 Chev pickup into a 4x4 by next spring. I had planed to sell the catagator and my 6 wheel Chaparel but never got around to it. This past summer my son bought a hunting camp. There is a good road to the camp but an awfull swamp to go through to get to our deer blinds. We spent more time getting unstuck with the 4 wheelers than we did hunting. My son then reminded of some of the places we drove the catagator when he was a kid. That's when I decided to fix it. I could probobly use it the way it is but the clutch cylinder is rusted beyond use. I might fix the Chaparel also. This should be a simple fix. I had a 300 cc Jlo which blew. I do have a sweet running 250 Rotax twin that I can put on. I have the tracks for the catagator but probobly wouldn't use them in the summer. I did put them on when I first got the machine but caused too much resistance between the machine and the road and snapped that # 50 chain a couple of times. Anyway, thanks for the reply and offer for the info on the manuals. If I owe you anything, let me know. Thanks Don (Packrat)
    Nov 2007
    104
    hi Don, no problem, I just sent the files to you. keep the cat. they are a kool machine. mine is the 6 wheel version. it has the big 24 hp kohler that weighs a ton. but mine still runs good so I will leave for now. my axles are wore bad. so I am going to have whipper make me some. this sight is really helpful and a lot of fun. Mike is to be commended for keeping it going for us all. oh and no pay is needed, we help each other here. I will send some pics to you.
