Adair shackle tracks?????
Results 11 to 20 of 32
Thread: Adair shackle tracks?????
    Mar 2015
    Hinton West Virginia
    22
    Make sense, my hinges are running thin. Adair it is, now I have to decide on adair shackles, adair pro 14.5 or adair swamp tracks
    Too many choices
    Mar 2015
    22
    I'm guessing these are shackle tracks?
    Adair tracks for a Max2 - Amphibious ATV Pictures
    Northern BC
    2,990
    Quote Originally Posted by eers2ya View Post
    Yes, that's them. I almost bought a set of those, but ended up going with the Pro Series for my Conquests.
    2,632
    a few things i like about the shackle tracks ( which may be only for max 2's ) are : they are very quick and easy to install and remove, easy to adjust length with the extra links they send (long, medium, short ) and even though adair does'nt make them, i just fabricated snow kit belts for mine adding more footprint. was easy to make the pieces and can be removed with little effort. j.b.
  5. #15
    Mar 2015
    22
    I run tracks all year, longevity wise, any clue which set of tracks last longer?
  6. #16
    2,632
    one other thing about the adair shackle tracks is if you wear anything out or break something, you can buy every piece individually. they consist of the connecting links, bolts connecting the metal shackles and the track '' feet ''. good luck on your purchase. j.b.
  7. #17
    Mar 2015
    22
    Thank you...
  8. #18
    Feb 2014
    Central Saskatchewan Canada
    171
    If you have not purchased tracks yet, check out the Chanel tracks. They are made in Canada, you will get about 35% off the price right now with the exchange, they are very tough and adaptable. The steel cleat has very good traction and Marcel is excellent to deal with. You do not need the Tuners to run Chanels or Escargo tracks but any track will run better with them. You do not have to worry as much with indexing and pressures. The Adairs are very good to, if you have lots of rock, they would not be my first choice.
  9. #19
    Jan 2016
    Berlin Wisconsin
    93
    The Adair shackle track, or classic track was designed to compete with other similar track types at a lower price point than the pro series.Adair builds very few of these any more, mostly the pro series. After seeing lots of pro series tracks with lots of hours on,the only thing that was wearing, was the surface of the grosser that comes in contact with the ground. This actually improves the traction in certain situations as the surface grabs more.The pro series does not wear on the sidewalls,or on the tires that much at all,and is half the weight of the escargots.IMO, the last thing that will fail on your unit will be the pro series tracks,as they are tried and true.
  10. #20
    Oct 2010
    Wasilla, AK
    923
    Lets keep it fair. I know it's a shackle track thread, and I know it's your job to market what you sell, but you gotta keep everything on the up and up.
    Your track comparison weights are incorrect by a long shot, even for escargo
    You sell and market the pro-series tracks and are a 6x6world.com site vendor or sponsor best I can tell, so it's probably okay?
    What does a pro-series or shackle track weigh, and what is the cost (probably varies by model)?
    For comparison, a 19" wide channel track for a conquest 8x8 is 97 lbs. Moving to an 21-21" avenger track adds maybe 10-15 lbs.
    The lowest possible price point with the best possible performance should be the goal of any track. Wear life of ground-contact surface is certainly one factor though and I believe the one that was in question
    I get the impression (via the website) that the shackle tracks are more expensive than the pro-series. What is the main benefit to running shackles vs. rubber belting on a ground-level flat-belted track such as the pro-series?
    For clarification the channel and escargo style tracks are "elevated-belt" tracks.
