Amphibioius Atvs Logo
Go Back   6x6 World > Tech Talk > Tire and Wheel Talk
Tire and Wheel Talk Tech talk for any and all tires and wheels.
Reply
  #1 (permalink)
Old 06-03-2008, 09:23 PM
racerone3's Avatar
racerone3 racerone3 is online now
6x6 World Sponsor
racerone3 is on a distinguished road
screwing tires to rims?
i've read on off roading sites about using sheet metal screws through the rim and into the tires bead with non beadlock rims. anyone doing this on their aatv's. i tore the bead on one of my tires mounting it, so it's already full of slime. i read a post a while back about slime acting as a lubricant to make the tires slide off the bead, so i want to ensure that they stay in place. any advice (and pics of where in the bead you put the screws) would be highly appreciated
__________________
"momentum is your friend"
  #2 (permalink)
Old 06-03-2008, 10:29 PM
Swamper's Avatar
Swamper Swamper is offline
My other ride is an LAV
Swamper is on a distinguished road
Hey racer, I haven't used screws on the tires on my Argo, but we used to use screws on the slicks on the race car until we bought bead lock rims. The screws were evenly spaced around the rim and were centered in the lip area of the rim. You could align the screws with the 5 mounting holes in your rim. Leave a small space under the head of the screw so when the bead flexs a bit it won't pop the head off the screw. I would think that a # 8 or #10 sheet metal screw would work. Don't get ones to long because it will probably leak air. We used screws that when we left about 10 thou of clearance under the head, the sharp end of the screw did not go through the bead all the way. A little of bit silicone on the screw when you turn it in will help against an air leak. Hope this helps you out.
Cheers, Al
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
