Gas leakage anyone ?
Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Gas leakage anyone ?
    Mar 2016
    Oshawa Ontario Canada
    184
    Well i figured it out.. but man, do i wish it was something else... so far i saw 3 cracks , one bad one, on the top of the tank...not sure if i can fix it, was thinking of using "2 part epoxy glue" and fibre glass cloth. Scuff the tank around the cracks, coat the area in epoxy & soak the fibre glass in the epoxy and cover the cracks... anyone ever try thy this ?
    "I've yet to encounter a problem that cannot be solved with the right mixture of whiskey and weaponry"
    :ME....
    " From my cold dead hands"
    :Charlton Heston...
    Fairbanks AK
    1,457
    Hate to say this but Idd purchase a new tank. Next place they crack is on the sides.
    Mar 2016
    Delaware
    328
    Pl 5200 marine caulk. sand the area first then do a solvent wipe (zylol) let dry thoroughly. Apply caulk
    Mar 2016
    184
    Said screw it & ordered a new tank, figured don't want to fix it and then have a crack somewhere else. Tank is 23 years old and if it's cracking for no reason on the top then its probably getting brittle from age.. might as well get a new one and then it's one less thing I have to worry about...
    :ME....
    :Charlton Heston...
  5. #15
    to install or remove a tank you need to rmove the eat frame which has 6 or 7 bolts on each mid side of the argo.
  6. #16
    Mar 2016
    184
    Got the gas tank in today, can someone please explain to me why it wouldn't start and wasn't pumping gas up until I poured a little down the carb? I'm glad it worked I just would like to understand why. If I was to guess I would think maybe the fuel pump is not strong enough without the engine moving quickly?
    :ME....
    :Charlton Heston...
  7. #17
    you usually have to do that after not using it for a while or cleaning all the gas out of the lines, since its not electronice fuel pump it dont suck until the engine is turning so let it run on the prime you put in the carb and it will suck up eventually. since its a diaphram pump it relies on the crank case to blow and suck the fuel to the carb
  8. #18
    Dec 2008
    BelleRiver, Ontario,Canada
    14
    Hi Kris. I have a 93 magnum as well and it leaks gas too. Mine leaks right at the edge of the hose clamp where the filler neck is attached to the tank. Vent tube is also broken at the filler neck. must be a common problem with the 93 Magnum
  9. #19
    Dec 2008
    14
    I have a 93 Magnum too. Vent hose broken at filler neck. Filler neck tube is cracked right above lower hose clamp. Had to move clamp to actually see the crack. Must be a common problem with 93 Magnums
  10. #20
    Mar 2016
    184
    Quote Originally Posted by argo8mag View Post
    Mine is ok now that i put in the new tank. Old one had nasty splits in the top.
    :ME....
    :Charlton Heston...
