Conquest clutch belt vibration
Two trips ago my Conquest developed a pretty bad vibration in the clutch belt. At about 2800 rpm it has a very visable vibration inn the belt. After changing the clutch weights in the primary for high altitude and putting the secondary spring in hole #2 it was running as smooth as ever.
The only thing I did different before the vibration happen was to put a new belt on that was a hair tighter being new. After the vibration i swapped the old belt back on but it is doing the same thing. I checked th bolt on both clutches and they were tight. I also tighten the idler chains a bit.
The only thing I notice a foul is a shiny wear spot on the base of the secondary spring housing. I am in the process of taking that apart.
Is there a top/bottom to the way the secondary spring goes in? Is it possible to get the transmission tilted enough to throw things off after tightening the idler chains?or any other thoughts???
