At low speeds clutch wants to lock up?? especially when it warms up.:hmmmm2:
Printable View
Usually clean and lube the rollers helps. Depends on engine size as to what clutch you have.
My 780 did that, found a broken arm on one of the rollers under the cover. Scrap!
I will take a picture and post it. I assume the rollers are in the top pully?
Thanks Nubs for the picture.
Does it need to sprayed with silicone like the secondary?
I took the clutch plate off and oiled the rods. it seems to work better.
