Popsicle T-20 band wear questions
+ Reply to Thread
Results 1 to 8 of 8
Thread: Popsicle T-20 band wear questions
  1. #1
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Ok guys and gals I have never had this trans apart because it works just fine but I noticed after looking today that the plungers stick out of case prolly close to a 1/2 inch. Upper and lowers both! Is this an indication the bands are wore out??? And I've never had a trans fail yet so don't know what a band band will act like either!! Seems like sticks have quite a bit of travel to them also.
    Thank you in advance on this!
  2. #2
    Join Date
    May 2010
    Location
    Fairbanks AK
    Posts
    1,456
    If it works fine the lining on the bands is still there. As they wear the plungers come out more. 1/2" is getting a bit much but I've had new bands anywhere from a 3/8"below the face to sticking out 1/4". Must be just band length. Adjust the plungers to get about 5" of stick movement at the top and run it for a while. If the adjustment changes rapidly I would tear it down. I've had t20s that drove just fine and had paper thin bands when torn down.
  3. #3
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Quote Originally Posted by msafi65 View Post
    Is this 5" movement total stick travel?? I've never measured it but if i was guessing I'd say its gotta be at least 8" willcheck this out tonite!
    Thank you!!
  4. #4
    Join Date
    Jun 2007
    Location
    Buffalo, NY area
    Posts
    2,968
    Yup, about 5" of total travel at the top of the stick; front to back movement. If you have a lot more than that now, start with at least two full turns in on the top and bottom plunger bolts and see where that gets you.
  5. #5
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Quote Originally Posted by hydromike View Post
    Ok thank you Mike! I'll check this out tonite if not too many shenanigans at the waterin hole!!
    Happy St Paddy's day to all!!!
  6. #6
    Join Date
    Jun 2007
    Location
    Butler, PA
    Posts
    191
    If I remember correctly the spec. for band replacement is 5/8 of protrusion from the case on the older t20.
  7. #7
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Quote Originally Posted by Joe H View Post
    Ok Thanks Joe it still works fine but I was getting a little worried about tearing drums up!!
  8. #8
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Quote Originally Posted by dave phelps View Post
    Thanks again Mike!! Adjusted plunger bolts 2 turns in and sticks are at 5 inches,this machine has never been that tight!! I like it again!! LOLOL
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
