      1st generation attex 1" axle bearing styles
      LarryW
      6x6 World Sponsor
      The left one has a radius on the O.D. That style seem less common. I believe it to be a real early style?
      The right one seems more common and has a flat O.D. I believe it to be a better bearing because the bearing is held away from the body and closer to the tire. That take a lot of stress off the axle. Basically same idea as bearing extensions.
      When removing the axle, the outside of the axle is smaller (25mm outside /1" inside) so make sure you press it the right way out of the bearing.
      · Filesize: 38.6kb, 37.2kb ·
      Keywords: 1st generation attex 1" axle bearing styles
      Linked Thumbnail:
  1. Author
    Thread
    1. littleford68
      Registered Rider
      Mon March 1, 2010 7:39am
      so the bearing must come off tords the wheel side of the axle?
      This user is offline
      LarryW
      6x6 World Sponsor
      Sat March 6, 2010 5:11am
      Hey littlford68,
      Yes it does, the whole bearing/flange comes off the wheel side. The bearing pulles out of the flanges on the inner side towards the body.
