PlumCrazy
Registered: September 2009 Location: In Michigan out annoying the neighbors in something that has a motor in it! Posts: 484
T20 shaft removal, you can't see it but there is flat washer dropped down the shaft opening. Also added a nylon bushing on top of the washer. Both are used to protect the shaft end and the clutch ID. PBblaster was sprayed down the shaft opening.
