Custom Exhaust for Briggs Vanguard
  • Custom exhaust for your Briggs Vanguard!
    Well I finished my exhaust tonight and here is the info on what I did:
    the pipe I ordered from this site
    Exhaust Header U-weld Kit - BMI Karts and Supplies - Home
    With 2 of these kits I had all the bends I needed to make my exhaust in the size I wanted. The price was decent for mandrel bent tubing from what I've seen. I made the pipes 16 inches of 1 " O.D. pipe. I did this based on what the mower racing guys recommend. Actually they recommend 12 to 15 inches but 16 worked easier on my machine to get the exhaust to exit evenly. After the 1 " pipe I opened it up to 1.25" O.D. pipe for around 12 inches to exit the machine. The flanges I ordered direct from Briggs Part #692074 this should work on most Vanguard engines.
    I had a local welder weld it for me. One note here I tried to have it welded off of the machine but it is next to impossible to get everything correct without tack welding it while on the machine. My first attempt ended up horrible I had to buy more flanges and if you look close the pipes are a little to the right of center because of what I had to cut off. Oh Well live and learn!
    I finished it off with 2 RLV silencers for 1 5/16" for modified engines these can be purchased on any Kart racing website. To clamp them on I used 2 piece split shaft collars in 1 3/8" and these worked better than I hoped. I then used a standard ratchet clamp to stabilize them together.
    I may attach a metal brace to the engine if it needs it
    Mike
    Click image for larger version
ID:	355318Click image for larger version
ID:	355319Click image for larger version
      Posting comments is disabled.
    article_tags
    Latest Articles
    • Pressure lubricating a Max throttle cable
      by MAX IV Mark
      Every time I go to start my Max in winter the throttle cable is frozen. I have a heated throttle cable but it takes about 20 min idling to get it free. I figured a good way to lube, purge the water and keep it from freezing.
      I took a condiment squeeze bottle I had laying around and filled it with antifreeze. You could put your own mixture in it if you are worried about using antifreeze.
      Removed the engine cover to get at the cable end. This engine is the 29 Kawasaki...
      01-01-2014, 12:32 AM
    • Max II Engine Replacement
      by Mike
      This article will act as a basic guide for removing and replacing the engine in a Max II AATV. Before you begin be sure that you disconnect the battery under the seat. Note: Click thumbnails to view larger photos
      Start by disconnecting the ground strap and the throttle and choke cables at the motor. Then disconnect the wire at the starter solenoid, the electrical connector at the front of the engine, and the fuel line (1,2,and 3 respectively in th...
      02-11-2010, 10:54 PM
      by micmac
      Exhaust Header U-weld Kit - BMI Karts and Supplies - Home With 2 of these kits I had all the bends I needed to make my exhaust in the size I wanted. The price was decent for mandrel bent tubing from what I've seen. I made the pipes 16 inches of 1 " O.D. pipe. I did this based on what the mower racing guys recommend. Actually they recommend 12 to 15 inches but 16 worked e...
      02-11-2010, 10:28 PM
    • Small Engine Maintenance
      by Mike
      Many 6x6 ATVs utilize small engines for power due to their availability, price, and reliablility. These engines can provide a lifetime of trouble free use if you properly maintain them. Of course anytime that you subject them to abrasive environments you will have to maintain them more frequently and if you happen to be as unfortunate as my Max II in this photo it and submerge the motor under water you should always change the oil and filters. Here I will list the recommended maintenance sched...
      02-11-2010, 10:19 PM
