Winch wiring with a solenoid pack
  • Winch wiring with a solenoid pack
    Types of configuration:
    1. Direct inline control. This means the switch carries the total current supplied to your winch (this means bulky cables and possibly less torque capacity of your winch).
    2. Indirect control by means of current amplification. This basically means that you put an amplifer close to your winch so that the amperage needed by your winch does not have to go through your directional switch. Some current amplifiers are called relays, solenoids or solidstate (transistors, mosfets...)
    Wiring of a realy winch controller and Theory:
    Although solidstate is one of the best forms of control (with the added function of speed control), the relay option is probably the simplest way to get around a "direct inline" type of control. A relay configuration to control both forward and reverse directions on a motor is known as an H-Bridge. The following diagram explains the setup:
    Click image for larger version
    The picture shown is better known as a winch pack or solenoid pack, but regardless, does the function of letting a small current control a larger current and it's polarity acting on the winch motor.
    In one direction of the toggle switch, (lets say up in the picture), the relay on the top left and relay on the bottom right activate (or pull in, or "make contact"). This makes the left side picture (to the motor) positive and the right side -, thus turning the motor in "A" direction.
    In the other direction of the toggle switch, the relay on the top right and the relay on the bottom left activate and make the left side picture - and the right side +, thus turning the motor in "B" direction.
    In this senerio, the toggle switch can be placed anywhere, including on a remote wire of X feet so that you do not have to be in the vehicle during winching. And/Or you can wire a toggle switch into the dash to do the same job (put the switch in parallel with the other one if you have two).
    The H-Bridge should be placed as close to the winch as possible as to reduce the amount of power loss through the heavy cables attaching the winch to the battery (via the H-bridge).
    Cheers,
    Beeman
      Posting comments is disabled.
    article_tags
    Latest Articles
    • Adjusting Chains and Jackshafts on a Max II
      by Mike
      For anyone new to six wheelers, this is a short video showing you how to adjust the chains in a Max II. There are eight chains that need to be adjusted. The chains between the front and middle axles and the chains between the rear and middle axles are tightened using the ratcheting chain adjusters. The ones in the front are adjusted by pushing the adjusters down. The ones in the rear are adjusted by pulling the adjusters up. The remaining four chains are adjusted by moving the jackshafts. ...
      03-14-2011, 11:05 PM
    • Repairing a Grooved Axle
      by Planter Bob
      Do you have a grooved axle and a shallow wallet? Well, here's the ticket for solving the problem without burning up the Visa card.
      Repairing a grooved axle on the cheap: 1. Remove the axle. 2. Clamp it firmly in a smooth-jawed vice, with the groove about 6" from the jaws of the vice. 3. Using a wire brush in a 4" grinder, clean all the area in and around the groove, making it free of rust and gunk. Use a flat file gently on any high spots. 4. Use paper towels and wipe down the...
      09-15-2010, 09:07 PM
    • Upgrade your Argo Conquest bearings to HDI
      by Rock Doctor
      Well, I finally got this little project started. I think everything is going to work out good, but there is still some testing to do. I ran into a couple little issues, but nothing that can't be dealt with. Sorry about the length of the vids, it was hard to keep the time down on a project like this. I have only uploaded the first part so far, but PT-2 will be edited into this post tomorrow if possible. I have to say here that I'm NOT SURE if this will work with ALL Conquests. I have noted that some ...
      06-07-2010, 09:05 PM
    • Bronco Seat for your Six Wheeler
      by racerone3
      i've needed to redo the seats in my wild wolf for as long as i've had it. the seat back was the original and shot, and the bottom was something i had quickly thrown together. last week after months of my son begging me to take him for a ride in my old bronco, i finally got the back seat down from the rafters of my shop and bolted it in. later that night it dawned on me that it would make a pretty good seat for the Wolf. i checked with the place i'd gotten my seat covers form when i built the bronco...
      04-13-2010, 09:57 PM
    • Used ATV Buyer's Guide
      by Mike
      General - Purchasing your first six wheeler can be exciting and it is something that many of us remember well; Seeing it for the first time, the test drive, towing it home, taking it for a spin around the yard and realizing how quickly you can tear up the grass. But it can also be an intimidating process especially if you are not purchasing new. For some, a new six wheeler is simply out of the question. Whether it is financial concerns or simply that the six wheeler you are looking for is no...
      02-28-2010, 01:23 PM
    • Heatgun Body Repair Oxidation Video
      by REB181
      How to bring the shine back to your HDPE Polyethylene body. Works on any 6x6 or 8x8 HDPE body and is simple to do.
      http://s239.photobucket.com/albums/f...unbodyclip.mp4...
      02-12-2010, 08:50 PM
