T-20 Skid Steer Transmission Rebuild
  • T-20 Skid Steer Transmission Rebuild
    Here are steps in the first part of the T-20 rebuild. Make sure everything is on a clean surface and that you keep your parts organized. The T-20 is actually easy to work on after you get the hang of it. Follow these steps to get yours apart, then the second part will deal with reassembly and the installation of the new components (O-rings, gaskets, etc.) Good luck and happy 6 wheeling!
    1. After you have removed the T-20 from your machine begin by emptying all of the fluid by removing the drain plug on the lower part of the unit.
    2. Begin by taking all of the nuts and bolts out that hold the two T-20 halves together.
    (Note: Click on thumbnails for larger images)
    3. Carefully pull the two case halves apart.
    4. Next, you will remove the pins that hold the bands tight against the drums. I usually start on the side that is open and doesnt have the plate over the assembly (as seen above in step 3).
    5. Take out the first drum with the planetary gears. Be careful when taking these out so the gears dont fall and so you dont lose the needle bearings inside them.
    6. Now take the small retaining plate the planetary gears ride against. Pay attention to the location of the fiber thrust washers. The location varies by year the T-20 was manufactured. Some years there were none used as well.
    7. Take the second drum out of the case. Notice the fluid on the drums and in the case is the correct red color ATF. If the someone put in fluid that turned black, it is most likely gear oil. Wipe down and clean your bands, and the rest of your transmission because gear oil can actually cause the band material to separate from the metal.
    8. Now you should just left with the bands in the transmission.
    9. You will repeat the same process with the other side of the T-20, but first you have to remove the large round plate that covers it. Your best bet is to use the metal shifter retaining piece that came on the later model T-20's to take the "C-clip" off of the main shaft. If you don't have one of those, you could probably fabricate something to help. Tap it with a hammer, but hold a rag up to the shaft because it will go shooting across your garage and there is a good chance that you could lose it. Sometimes this step takes a couple tries since there is so much "spring" to the C-clip here.
    10. If the C-Clip doenst come all the way off after the previous step but moves just a little bit, take a flat blade screw driver and pry it out the rest of the way. Keep the rag up against it so it doesn't go shooting across the room as I mentioned.
    11. Pull the plate off along with the small gear on the shaft above the plate and the other small gear on the shaft below the plate.
    13. Now repeat steps 4-7 with this half of the T-20.
    14. Next, take the lever that works the steering plungers off. This lever could be a piece of flat steel if you have a earlier style transmission, or piece of "U channel steel" on the later models. Push each of the steering plungers into the case through the holes bored into each case half. You may need to lightly tap them with a hammer.
    15. Now pull the brake bands out. Keep in mind which one goes on what side of the case. You might want to mark them, or put a piece of tape on them to show you which one goes where. This will be important for reassembly.
    16. Repeat steps 14 and 15 for the other case half. Now you have disassembled your T-20. The second half of this article will cover reassembly and installation of the new parts (gaskets, O-rings, etc).
    Copyright 2007 (JP) For use only on www.6x6world.com
      Posting comments is disabled.
    article_tags
    Latest Articles
    • Easy T-20 split shifter Guide
      by Rabbit929
      This is on a 94 Max II 18hp Briggs and Stratton You will need: Grinder Welder I got all my parts from tractor supply. Parts List: -1/2x1x2 inch steel bushing (anything will work but the inside diameter needs to be 1/2in) -1/2in steel pipe (hollow or solid, you only need about a foot) -shift knob of your choosing, I haven't found a matching one yet. -2 1/2in inside diameter spacers/washers (the think ones) Start by cutting the cross shaft. I cut mine an inch and a half from the ...
      10-31-2016, 05:36 PM
    • T-20 Assembly video
      by George
      This video walks you through the assembly of a Borg Warner Skid Steer T20 transmission.
      09-26-2012, 06:59 PM
    • Rework an Early T20 to Accept Thrust Washers
      by whipper-ag
      I'm sure that some of you have opened up some Early T-20's & found them FUBAR. Once the gears start digging into the drum face, it doesn't take long to ruin the bearings, wear the bands down & cause excessive wear on the ring gear. Fortunately, all is not lost. In most cases, it can be modified to add the fiber thrust washers which are now used in the Late Model T-20's. Here's a video how to do it.
      Whipper :6x6burnou t:...
      02-18-2012, 11:18 PM
    • Max II T20 Split Shift Modification Video
      by LarryW
      This is a how-to video for making a split shifter for your T20. While I did the modification on my Max II, the same principals will apply on most Borg Warner Skid Steer T20 transmissions regardless of which ATV it is in. Instead of having one lever that controls shifting of both sides this mod will let you shift each side of the transmission independently allowing you to counter rotate. I even got to scare myself a little.
      03-22-2010, 08:47 PM
    • T20 Skid Steer Rebuild
      by Mike
      Borg Warner T20 Transmission Rebuild A large percentage of 6 wheelers utilized the Borg Warner / Skid Steer T20 transmission. While they are virtually indestructible when properly maintained many of these skid steer transmissions have been around for over 30 years. It is only natural that at some point in their life whether it is due to improper maintenance or old age, they will need new seals, bands, drums, o-rings, or bearings. This article will walk you through a tear-down and re...
      02-12-2010, 06:29 PM
    • Salsbury Clutch Rebuild
      by Don
      How-To rebuild your Salsbury Clutch Salsbury was a very popular brand of clutch system for many of the amphibious ATVs from the 1960s to around 1980 when they closed up shop. Attex, Hustler, Scrambler and Max used them on at least some of their models, and I'm sure more of the lesser known machines used Salsbury as well. Attex used model 910 for the ST400, Chief, Thunderchief and Superchief and the 780 for most of it's single cylinder two-strokes. I'll try and be clear on how to do a...
      02-11-2010, 11:36 PM
