2006 argo avenger with tracks
  • Rock Doctor
    replied
    I have the low geared Trans in my machines, so rarely use low gear.
    I would suggest running in High until you cant, then shift it down when needed.
  • ARGOJIM
    replied
    Like these guys wrote, will depend on load and terrain, rubber tracks may require low more than super tracks.
  • glen1971
    replied
    I'm with Bob on the gears. I run an 07 Avenger and am usually in high gear, unless I'm on a steep hill, heavy loads, deep snow, or thick mud. Lately I've found that I don't need the tracks as much as I had in the past. It's a bit easier on the machine, but I still have them in camp, in case I need em.
  • Avenger Bob
    replied
    I have a 2008 Avenger and I use both gears as appropriate. Low for steep hills, heavy loads and deep snow on trails. High on flat straightaways like frozen lakes, especially if they are slushy.
  • Haishi
    started a topic 2006 argo avenger with tracks
    What gear should I run with tracks, high or low
