Regardless, you still should not turn from a stand-still on concrete, tarmac, pavement or any such surface. Doing this puts a lot of pressure on the drive system.
Congratulations on getting you Max running.
Lack of turning power
hey hack, good for you and congratulations ! we all know how frustrating it can be when somethings not working right and we can't figure it out. i know for myself, especially being a inventor , you want to give up but your intuition says try one more time. and when it work's we are glad we kept at it. now you will really enjoy the max even more. have fun and post a video when possible. thanks for sharing. johnboy va.
SOLVED:::: Lack of turning power and speed
well guys Finally it has been solved... .You will remember from my previous post that i had purschased a used max iv and that as soon as i tried to drive it i noticed that the machine had no power no speed and could not turn on tarmac or concret. Many told me it could be the belt and some said that it was just that the max on concrete wouldnt turn that easly, however i still had my doubts because of seeing videos the max had enough power to turn in deep thick mudd and second it should be able to turn from a standing still point. many people told me to contact Argo adventures and max and order the belt since i couldnt find it anywhere. i called and Ed from Argo adventures and max was very helpfull and guided me to what belt i need and placed the order and shipped it fedex internationaly to me which i recieved in 3 days.we installed the belt and the mechanic drove it measuring the speed and to our sprise it was only doing 10 miles an hour, and since i am new to these 6x6 i though that was normal and so did the mechanic but again i called ed and asked him and he said it should do 25 to 30 mph.i gave up and was going to sell my max very cheap but i decided to call Ed again from Argo adventures and max i told ed my issue and told him i give up so he told me do this before you give up open the spark plugs on both the front end and the back end and measure the pressure and tell me.....so i told him the front spark plug pressure was giving me a 100 percent reading while the back spark plug was giving me 40 percent. Ed told me there must be a problem with either the carborator or the pistons. the mechanic opened the carborator and opened the steel plate concealing the rockerarms and suprisingly we found one of the rockers arms rod bent and the valve completly rusted. so he cleaned the valve and fixed the bent rod and called me in to test the max again after we fired it up and drove it again the max was slow. again i called my friend ed and asked him what should we do next he told me did you check all 4 rods and when i asked the mechanic he said no it only has 2 rods anyways ed told me there are another 2 rods located at the side exhaust which the mechanic didnt know about. so again the mechanic open the side rods and again to our suprise it was fully rusted and the second rod was also bent. so we repaired it and before we closed the engine ed adviced me to check the main jet A and main jet B fuel pipes,,,,,and we did again ed was right they where nearly blocked so we cleaned them up closed the engine and fired it up. Wooow that thing just jumped from the start and when turning from a stand still it was like a fan blade spinning
.......Before i end this thread i would like to take a few moments to show my gratitude and to thank ED from Argo Adventures and Max if it wasnt for him i wouldnt have solved this issue. I honestly have called him over 20 times and every time he was so supportive and so helpfull and guided me in details on how to solve my issue and he also emailed me the engine manuals and pictures. Furthermore all my orders where shipped so fast. ED if you read this post thank you i really am greatfull that from thousands of miles away you helped me get this max back to its working condition... i now love my max and love the power it has. please see attached photoof some of the rusted valves. i dont know if i could attach a video to show you guys how it spins. anyways hope this helps some other people facing the same issue. By the way my engine is a 27.0 hp kawazaki.
Attached FilesLast edited by Hack4Life; 08-22-2014, 03:03 PM.
Guest repliedWell I am glad you got things figured out I had some problems myself Its a good feeling when at least you found the problem and can now know what to do to correct it GOOD LUCK
Dave G.
Lack of speed and turning power part 2
So guys i think we finally found why in my previous post i listed there was lack of speed and turning power. So finally after i got the drive belt from mudd-ox thanks to Ed very nice and very helpful guy who shipped it internationally to me in 2 days only. So we installed the belt easily with out opening any part just by sliding it and twisting it on anyways i fired it up and when pressed full throttle it bearly moved so slow however when turning on tarmac amazingly even though so slow it turned fully but slowly. So i drove with the mechanic next to me and pointed out that its so slow. So we stopped and he removed the carburetor and noticed that one of the carburetor heads shot air out while the other was completely blocked. So he then opened the spark plug at the back of the kawaziki engine not the front and measured the pressure and was amazed that it only shot up to 30 percent while the other spark plug pressure shot up to 100 percent. He then opened the rocker seal and amazingly the right rocker arm was completely bent and stuck below. So now i will have to order new rocker arm and maybe a new piston. See the picks below i just dont understand what could have caused this.
I had problems turning when I first started driving too. I thoughy my Max wasn't running right or something wasn't adjusted properly. I jacked up my machine and got all 6 tires off the ground to observe what was happening. It all looked fine up in the air turning left & right, forwards and backwards. Watching it operate this way showed me that eveything was working as it should. But as everybody here already stated, there is a lot of stress on the machine when trying to turn from a standstill on dry pavement. You need to give it some gas to get it to spin this way.
Oh and with the truck, to check if belt is wore try sliding back the engine (4 bolts on the engine block), if it gets better buy a belt.
If you're playin with the truck, Goodyear belt is all I've found.
As for Drew's post, we all need a paid vacation, fixin and ridin a machine is a plus!
Try the Max manufacturer, Mudd-Ox.
The belt is also equal to Dayco HP 3029. I found this info in another thread.Last edited by Rusty-Gunn; 08-10-2014, 06:59 AM.
can someone please help me my belt is completly worn out and since they dont sell parts here i want to order from the states however the belt number is 018039 the mechanic told me and i went to Welcome to Richard's Relics Parts for Amphibious ATV's, and cant find that belt.
amphibious drew thank you so much for your reply and encourgment i honestly am proud and happy to have joined this web site and to recieve all this support from you guys.i am also relieved and now looking forward to fixing these 2 machines , i will follow your advice and keep you updated god bless.
I'd gladly come over and help fix them. Of course would need my travel taken care of. Lol. Seriously, it may be that your throttle cable isn't getting full throw. Try adjusting it at the engine. Simply loose. Up the cable cover screw holder and pull the cover away from the the engine a fraction of a centimeter at a time. Make sure to re-tighten the screw and take it for a test spin. Any small engine shop should be able to work on your engine. If the tranny needs adjusted, watch the video on the home page here and do it yourself. I have no formal mechanical training, and with the help of this site, can rebuild a t-20 in a short time, can diagnose and tune my engine and drive train, and can rebuild a machine from garbage. These things are simple, and everyone here is willing to help any way they can.Originally posted by Hack4Life View Posti give up on these 2 max that i bought and dont know what to do the problem is that i live in dubai and these machines are not sold here and no one is qualified to fix them i am hundred percent sure that both these are lacking power and just dont know where to start as i myself lack any knowledge about max's. i cant just go drop it and get it fixed since they lack the knowldge here as well i just dont know what to do im really sad because i do love them but if they are working correctly. damaged they are not fun to drive nor keep. ooooh what a day.
Hi hac4life
The clutches are similar to side x side UTV and some quad bikes
The engines are quality lawnmower .
After u read the overhaul/maintenance pages on the t20 all workshops should be able to handle them.
Present the info/manuals on the engine /transmission /max to your trusted repairer and go from there .
4 parts find the country closest to u that has an agent or buy straight from the factory .
If your mechanic is any type of business he will take care of it for u . The repairs will cost a little extra as a result .
tomo
PS Some of the guys who have experience with dunes may respond .
As with my experience with NONcompactable river sand ,all my 6x6 does is dig trenches . Hard pack sand is completely different .Loose sand eats up horsepower quickly . Typically high engine revs and speed is the answer .Last edited by Tomo; 08-09-2014, 03:12 AM.
These machines are really pretty easy to work on, don't get discouraged. Your engines are just about the same as big lawn mowers, find a good small engine repair shop and they should definetly be able to fix any engine problems you have. As for the trans you should do some reading on the t20, their very easy to work on once you figure them out. Your problems are probably very small.... Norm
