Popping while turning
  • Buzz
    replied
    I bought 10 feet of HD 60 for 37.50 plus the shipping cost to my zip code. What did it cost you to buy double 60 chain to replace all of the chains on your MUdd-Ox?
    enough 60 chain for a 6x6 is less than enough 60 chain for an 8x8, especially if it's twin 60. Not to mention everything costs less where you live that it does to buy in AK or buy/ship to AK. 4 small tires on my commuter car cost less than 6 new 10 plys for my truck.
  • mudbug3
    replied
    Originally posted by gokorn1 View Post
    we replaced the chains and so far so good. well see how the stretch turns out
    I bought 10 feet of HD 60 ( 9,500 tensel strength )for 37.50 plus the shipping cost to my zip code. What did it cost you to buy double 60 chain to replace all of the chains on your MUdd-Ox?
  • amphibious drew
    replied
    Chain is a where and tear item. eBay has good deals on chain if you watch for it. Just make sure you buy high quality stuff. There are plenty on threads on here that discuss the topic.
  • emolson
    replied
    I was wondering if that fixed the problem as mine is doing the very same thing!! Where is the best place to buy replacment chains?
  • gokorn1
    replied
  • akexpress
    replied
    The 2010 version has a different chain tensioning system then the 09 gas model.
  • stid2677
    replied
    Originally posted by Cougar View Post
    When you where tighting the chain was the tires off the ground? What chain is it 1st, 2nd or 3rd ? If you didn't have the tires off the ground you can't get the chain tight. Hope this helps. Cougar
    My 2010 Diesel was doing the same thing on the right side,, it turns out that the bearing in the drive chain tightener was bad. It is easy to check,, just find the masterlink and disconnect the chain once you have loosened the tightener,, the tightener will slide off the adjuster bolt.
  • akexpress
    replied
    I know this machine has argo rubber tracks on it. to properly adjust the tension on the chains the tracks need to be removed. Also add some star type lock washers under the adjusting bolts so there is a little more friction so the adjuster pads don't slip down. These two things should eliminate the popping. I would also recommend the rear chains be removed when using rubber tracks to help eliminate chain windup.
  • mudbug3
    replied
    Matt Oxender is the man who designed the Mudd-Ox since its inception and he would be the man to call about this issue if you can't get it resolved.
  • Obsessed
    replied
    You might just try calling Matt at Mudd-Ox and ask him. He designed it and is probably your best resource for repairs and upkeep. Im sure he will be happy to help :-)
  • Slimpickin
    replied
    You might have a bearing out, giving it slack and allowing the chain to jump
    Slim
  • Cougar
    replied
    gokorn1 I sent you a PM. Thanks Cougar
  • gokorn1
    replied
    Yes the tires were off the ground and its the chain that links the front tires to the rest
  • Cougar
    replied
  • gokorn1
    started a topic Popping while turning
    Im posting for a buddy who just bought a 2009 Gas Mudd Ox.
    The problem we are having is that when were are turning tight circles the left side chain pops. It is not was tight as the right side. So we adjusted the tensioner and it will just push it back up.
    Just wonder what else could be the problem
