Originally posted by dirtdobber
View Post
18 hp briggs and stratton smoking
20170501_192350.jpg20170501_210325_001.jpg20170501_210759.jpg20170501_192350.jpg20170501_210325_001.jpg20170501_210759.jpg
I'm not sure what normal is for these engines, but 170 does seem high. If I'm applying the right logic, pressure and volume are proportional. With atmospheric pressure being 14.7 pounds, and assuming the pressure inside the cylinder on the intake stroke is 14.7, then then it has to compress 11.5 times to reach 170 psi. A good old stock Chevy small block engine would have somewhere around a 8.5:1 ratio, but I'm not sure what these engines should have. But, I can't think of anything that can go wrong and cause increased compression, unless maybe the exhaust valve is not opening and the cylinder is able to draw in a little more air than normal and thus is reading a higher compression (that's just a wild guess, by the way). Especially since the compression on one cyl. is nearly double the compression on the other. You did read your gauge right (psi) and not some other units??And isn't 170 too high? I thought I read that 90-110 was more normal?
Post some pics. Not sure if they will help but pics are always fun to look at.
Thanks HipoweroneOriginally posted by hipowerone View PostYou can add photos by "GO ADVANCED" option on a post, then scroll down and "MANAGE ATTACHMENTS" where you can "ADD FILES" and upload them to the site.
One side was 90, and the side I pulled the head on was 170. When I did the pull the pull the plug wires test, unplugging the 90 cylinder caused it to run rougher, whereas unplugging the 170 cylinder caused no change to the way it ran. I thought that indicated that it was running more on the front cylinder the 90 one than the back one the 170? And isn't 170 too high? I thought I read that 90-110 was more normal?Originally posted by dirtdobber View PostJust curious.....why did you pull the head from the good side (higher compression side)?
Is there a way to post photos here? I pulled the head tonight that had 170 compression. I think it might be a valve guide? Would like to.post a photo so someone could maybe confirm. Never opened a small enginr head before so not exactly sure what it is supposed to look like.
Got out to the garage tonight and pulled the head that had the head that read 170 compression. Took so.easy photos of the head and the valve springs and guide. I think it might be a valvr guide? Is there a way to post photos here?
Snuck out of work at lunch. Checked the tappets adjusted one a tiny amoumt all are .004 did a new compression test still 90 in the front cylinder and 170 in the back. Could it be my compression relief?Originally posted by ARGOJIM View PostAdjust the valves, one may be too tight allowing some compression to escape. Redo test.
BTW when we bent a pushrod our machine smoked violently.
Checked the push rods they are all straight. picked up a feeler gauge but wont get a chance to work on the machine again until Thursday night likely, will check all the valves and set them all the same between .004 and .006 Correct?Originally posted by ARGOJIM View PostAdjust the valves, one may be too tight allowing some compression to escape. Redo test.
Adjust the valves, one may be too tight allowing some compression to escape. Redo test.Originally posted by Trapper Dano View PostJust did a compression test on the motor a hair under 90 on the front cylinder and about 165 on back cylinder? the smoke is white
BTW when we bent a pushrod our machine smoked violently.Last edited by ARGOJIM; 04-25-2017, 10:04 PM.
Just did a compression test on the motor a hair under 90 on the front cylinder and about 165 on back cylinder? the smoke is whiteOriginally posted by dirtdobber View PostThis is normal operation, if I understand what you are asking. When the rocker arms are "up" the valve is closed. On the compression stroke, both the intake and exhaust valves are closed (thus both rocker arms are even); otherwise you will have no compression. The other cylinder will be on a different stroke (say intake for example) which requires the intake valve to be open and the exhaust valve to be closed. When a valve is closed there is a small amount of play (clearance) in the valve train which allows you to spin the push rod and will allow for some slack in the rocker arm.
The smoking problem is likely not related to the valve train based on your description. If the oil level was too high and had gas in it you need to look for a problem with the carb (flooding and dumping fuel in the intake) or fuel pump if it has a vacuum driven pump. It can have an internal failure and gas can be drawn into the vacuum line and into the engine. You changed the oil and the oil level is good. I would clean the oil out of the intake, make sure the spark plugs are good and run it for a while. Keep an eye on the oil level. If the oil level stays where it should, but the engine keeps smoking, then dig further.
What color was the smoke?
Just did a compression test on the motor a hair under 90 on the front cylinder and about 165 on back cylinder?Originally posted by dirtdobber View Postmake sure the plug is good on the back cylinder and that it is firing through the plug. If so, then run a compression test and see what that cylinder reads. Check the compression on both cylinders for comparison purposes.
There was another thread on here recently about rising oil level and oil in the breather of an engine. I'll try to find it and post it for you. I think it had some good instructions that may relate to your issue.
Here's one link that discusses issues that may be helpful to you, although a different engine: http://www.6x6world.com/forums/engin...-fuel-oil.html
Here's another link: http://www.6x6world.com/forums/engin...series-ii.html
racerone I pulled the plug and turned it over there is still good spark at that plug?
Thanks will be testing the compression tonight, if it all checks out will run it at what maybe half throttle for 20 minutes?
