Trans fluid
  • MikeyM
    replied
    Thanks, I ended up gettin stoppin by the dealership last night and gettin a quart of it. poured it in and buttoned it up, havent had a chance to drive it, but im taking it to a jeep jamboree this weekend so hopefully it can get some use. Thanks again
  • thejunkman
    replied
    Thanks buggyman i will try it
  • thebuggyman1
    replied
    The auto trakII fluid is an atf......no modern transfer cases use the 80-90wt.....even manual transmissions have gone to atf. the only thing that takes 80-90wt anymore is rear diffs and heavy equip(tractors etc.)
    Synthetic ATF will make the bands slip....smoother anyway. Your bands must slip to turn, and that creates heat.....heat damages the fluid, and synthetic holds up to the heat much better. It's that simple, no magic.
    Try it, and if you don't like it, switch back to the std atf with the additive.....no big deal.
  • MikeyM
    replied
    Originally posted by thebuggyman1 View Post
    The fluid is supposed to be changed every 50 hours of use.....If it smells or looks burnt, you better change it.
    The drain plug as you know, is not on the bottom of the trans. The trans must be tilted to get the fluid out......OR tilt the whole machine.
    I like using synthetic ATF......the heat generated is hard on the fluid, and synthetic holds up to heat better. The limited slip additive is not needed with the synthetic fluids.
    I spoke with another member at Ashtabula who is using 1 1/2 qt fluid in his racer... so a little extra fluid won't hurt. Just remember that alot of extra will hurt it.
    I just came back to look at your pics, sure wish I had my winch mounted so I could just raise up the front like that! You said synthetic ATF fluid, but your pic is of transfer case fluid, I thought t-case fluid was SAE90 rather than the thinner viscosity of ATF. Should I use the transfer case fluid or the ATF fluid?
  • azz7772
    replied
    I never had a machine with a t-20 but I had a bombardier bombi and it had a tranny with brake bands and this is the kind of oil that was recomended to me check the link.
    Hy-Gard
  • thejunkman
    replied
    I know about gear oil but i thought synthetic made the bands slip??
  • MikeyM
    replied
    Okay awesome! thank you! good to know about the synthetic atf! i'll grab some after work. And tilting the whole machine.....How I didnt think about that is beyond me, thanks for the tip! now I know it is on here somewhere, but to ease the search, I just pour the atf in the top hole until is starts coming out the bottom whole correct?
  • amphibious drew
    replied
    Originally posted by thejunkman View Post
    I thought synthetic oil was a no no in a t-20?
    Gear oil is the no no. synthetic atf is great.
  • thejunkman
    replied
  • thebuggyman1
    replied
  • MikeyM
    started a topic Trans fluid
    Trans fluid
    Hey all, I've had a problem with the lower plug on the Trans on my max II. Shane Kearny gave me advice of bigger tool solves the problem, tried it, and it worked. Fluid smells burnt, not bad but obviously due for a change. Or atleast topped off. How do I remove the fluid in the case? I'm really hoping the answer isn't what I think it is of pullin the Trans and dumping it out. That seems like the only feesable way to me. I'm just thinking if I need to top it off with X amounts of Trans fluid and X amounts of slip additive, I wouldn't be able to get the correct ratio with having the Trans empty to start from scratch. Thank you for any advice!
    Last edited by Mike; 07-12-2012, 05:10 PM. Reason: moved thread from Max forum to Transmission forum
