Carb issue - 16 hp briggs
Results 1 to 4 of 4
Thread: Carb issue - 16 hp briggs
    Idles great @ 900 rpm, but crack the throttle and you get a quick bog down the it speeds up fine. Droplets of gas come out top of carb when it bogs though.
    Overhaul carb?
    Ideas?
    Thanks
    Feb 2012
    Austin, Texas
    39
    You may be able to buy a new one as cheap as a kit.
    I would start with trying to gravity feed carburetor to eliminate fuel pump issues.
    Then move toward the carburetor repair
    Aug 2012
    Shipshewana Indiana
    350
    Quote Originally Posted by Jerry In Maine View Post
    Could the float be sticking? That would explain gas coming out where it shouldn't be.
    my .02 cents is to overhaul the carb, clean the crap out of the main and secondary jets, make sure you have a fuel filter inline, float adjusted properly, I have 2 in line, a grain of anything can cause issue's, it happened to me, hence my 2 filters. and never ever use gas with Ethanol
