Hustler 980 tall tub build
Page 3 of 11 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 109
Thread: Hustler 980 tall tub build
  1. #21
    Feb 2016
    Mississippi
    1,108
    Got the frame dropped into the tub. Amazingly, all 18 bolt holes for the outer bearings lined up perfectly, as did other bolt holes. Yanked it back out and got it all welded up. Now on to modifying chain tensioners.
  2. #22
    Feb 2016
    Mississippi
    1,108
    Update: I'm making pretty good progress. I have my new chain tensioners built and welded in. Motor mounts are about an hour away from being fabbed up and tacked together. If all goes according to plan, I hope to set the engine in position this weekend. It's going to be a tight fit. If I can get it in position and the mounts all tacked in, I can set the frame back in the tub, set the engine in place, and then see just how big of a job it will be to mount the original radiator.....if it will fit!!
  3. #23
    2,639
    it's going to be a really good machine that holds up well with all that work you've done ! that first ride will be exciting . love the rolling stand too . johnboy va.
  4. #24
    Feb 2016
    Mississippi
    1,108
    Thank you Johnboy. I'm counting on it being a long lasting machine.
    Here's the chain tensioners.
  5. #25
    Feb 2016
    Mississippi
    1,108
  6. #26
    Looking good, the frame looks really good.
    Countrycummings IV with the diesel worked really well.
  7. #27
    Feb 2016
    Mississippi
    1,108
    20200128_063910.jpg20200128_063931.jpgI stuck it together to better see what clearances I have. The factory radiator wont fit, so I have to come up with an alternative. I really want to keep everything under the engine cover....nice and neat.
  8. #28
    Northern VA
    2,766
    If your radiator setup is similar to mine, you can remove the fan spacer, turn the fan backwards and move the radiator about an inch and a half toward the engine. That gave me enough room to fit the original into the tub under the stock engine cover. Ended up making a new cover to install fans- the two cylinder was fine with the stock cover but the triple ran hot.
  9. #29
    Consider 2 or 3 atv radiators in line with electric fans either on right body ledge or across the back. Right body ledge would require cutting the body though.
    Btw Bo Clayton is putting together a ride or so in NE Texas on Facebook if you are interested.
  10. #30
    Feb 2016
    Mississippi
    1,108
    Don, thanks for the input and for posting your pic. I have been meaning to go find it. Unfortunately, the Yanmar engine is different. No fan spacer and reversing the fan makes it worse as the fan hub is dished to move it closer to engine already.
    AJ, I'm considering all options, including stringing together heater cores along the back screen or wherever else. Actually, I'm researching the John Deere gators. They made diesel models with nearly the same engine and smaller radiators. My radiator is bigger because it has an oil cooler for the hydraulic fluid, which I don't need.
