Max IV with Pontoons.
Results 1 to 8 of 8
Thread: Max IV with Pontoons.
    Jan 2017
    Fremont, Utah
    54
    I posted some pictures in the Gallery of my Max IV with home made pontoons. It can now haul over 700 pounds in the water. The Pontoons are made from 8 inch PIP water pipe (80 psi) with 4 100 psi caps glued on. The pontoons pivot off the roll cage and are pinned to the roll cage using 5/16 " grade 5 pins through steel strut. I used 5/16" all thread for U-bolts around pontoons and ran plastic tubing around U-bolts and a block of rubber between the pontoon and the strut. The pontoons are 9 feet long. It works really well, I float much higher and is very stable on deep water
    Jan 2017
    Fremont, Utah
    54
    I hope my video will show up.
    https://youtu.be/GT7G_6C54tE
    Jan 2017
    Fremont, Utah
    54
    2,639
    very cool !! looks like a little pontoon boat. you could camp overnite on it . johnboy va.
    Feb 2016
    Mississippi
    1,108
    Looks like that solved your flotation and stability problem. As a bonus they are probably easy to remove if you aren't going swimming.
    Jan 2017
    Fremont, Utah
    54
    Yeah, they come completely off very easily. Around here they would get broken off in the rocks. Even in the water I have to look for big rocks that might be lurking under the waters surface. It is fun running in deep water.
    Apr 2013
    Crestview Florida
    550
    good idea but they do look suspiciously like torpedo tubes!
    Jan 2017
    Fremont, Utah
    54
    Torpedo tubes? Hmmm, you're giving me ideas! Will need a mini gun on it too...
