InterMediate shaft issue ??
Results 1 to 6 of 6
Thread: InterMediate shaft issue ??
    I'm not sure if that is what it is called. I'm talking about the shaft w/sprockets that are right after the T-20. that "chain down" to power all the other axles???
    When I try to turn left if sounds like the chains are jumping. We pulled the upper tub and the chain is really loose,,sprockets don't look the best either.
    How do you get this assembly out w/o removing the T-20 ???? Is this shaft assembly available from anywhere??
    2,638
    if it's a max 2 you are probably talking about the '' jackshaft '' . the chain tensions are adjustable both the ones from the t-20 and the ones going down to the center axle. if the sprockets are really worn , no point in tightening up the chains real tight . i have never removed a jackshaft but someone will guide you in the right direction . if it's not a max...then someone else can guide you. johnboy va.
    yes it is a max 2
    2,638
    on the plates the jackshafts connect to , there are 2 bolts with nuts that pull the shaft back to tighten the t 20 chains and 2 bolts that pull the jackshaft up to tighten chains connecting to the axles. loosen the nuts that hold the jackshaft tight to the mounting plates then tighten the nuts that '' pull '' the chains tighter . then retighten the mounting plate nuts . make sure and adjust both nuts the same in order to keep the jackshaft '' parallel '' both horizontal and vertical . hopes this helps. maybe there is a video on it on u tube ... j.b.
    Nov 2009
    Michigan
    730
    Removing the jackshaft is just as easy as adjusting it. Remove the chain master links. Remove the adjuster nuts. Remove the mounting plate nuts. It will come out after that. Keep track of where washers are on the shaft.
    Quote Originally Posted by Toys4Me View Post
    The center shafts slide inside the battery box through the hole.
