Dazed and confused
Results 1 to 9 of 9
Thread: Dazed and confused
    Apr 2008
    Vassar Mi
    18
    Dazed and confused
    can anyone help me? I 16 hp Briggs & stratton engine that will only run on full choke. first, I checked the fuel the pump seems to be working and the carb has gas in the float bowl. next I pulled off on of the heads but the head gasket seemed ok. I still have to pull the other one any help would be appreciated.
    Nov 2008
    apex, NC
    263
    sounds like it may be an air leak somewhere after the airfilter
    you can find out by spraying wd40 around the carb and motor listening for changes in the sound all while making sure none of it goes in through the airfilter
    Try cleaning the carb/ports. You probably have some sediment in there somewhere. A bristle from a wire brush works well for cleaning each hole and then spray some carb cleaner through each one. Be sure not to miss the main one in the bottom of the bowl. That is often the culprit but you have to pull half the motor apart to remove it.
    Good luck!
    Nov 2008
    apex, NC
    263
    assuming the carb is clogged, assuming its not too bad, you could just run sea foam through it
    Mar 2008
    West Allis, WI
    383
    While you have the carb apart, check your float height. And check the float needle. Some of them had rubber tips that would deteriorate and clog the inlet.
    It's all just nuts and bolts.
    Definitely clean the carb. I had a similar problem. It was the carb jets.
    Mar 2009
    BERKELEY SPRINGS WV.
    179
    free talon
    i would go for the carb also it got my son a 250 talon dune buggy because my old boss couldn't get it to run. the needle valve stuck it wasn't getting fuel.runs like a charm now.
    Feb 2009
    Daytona Beach Fl.
    57
    Been there done that. I tried and tried to clean, rebuild my carb, broke down and bought a new carb and my motor runs sweet now. Suprising what a small spec of something can do.
    Apr 2008
    Vassar Mi
    18
    thanks for your help
