Dimension of the 1" idler bearing
Results 1 to 2 of 2
Thread: Dimension of the 1" idler bearing
    Feb 2019
    Germany
    28
    Hello everybody,
    i need to replace the idler bearing at my 1982 Argocat 8x8 with a Kohler M18 Motor.
    Wich Dimension has the bearing?
    For example, the axle bearing has this Dimension:
    31.75x62x30 mm
    Thanks from Germany
    Jens
    UC205-16SS unless it has a locking collar then UC205-16HC.
