I just uploaded a you tube vid under the name of Argo magnum startup,my channel is curtisbyrne,let me know what you think,need some help here:hmmmm2:.
Printable View
This should help: http://www.6x6world.com/forums/6x6-w...st-videos.html
Thanks mike lol,a bit of miscommunication there,I meant check out the vid I have posted on you tube.sorry about that should of said it better then that
Same as Zuk, searched for argo mag and curtisbyrne nothing found did you hit the publish button after you uploaded it?
Ok there singe vid let me know what you think.is the meter working?
is it working properly is what i meant?
Hard to tell. Did you test it at the battery with an external volt meter to see what it is putting out running?
Do the repaired wires have a full connection from one end to the other? Did the fuse blow again? Does it have a good ground from the battery to the ground bar? Did you run it for more than a couple minutes at mid to full throttle. Did you already replace the regulator as you were wanting?
I did not test wi volt meter yet and did not replace voltage regular either. Will check if the fuse did blow also
