I recently bought an old craftsman 46 inch dozer blade that I want to modify and mount on my Argo for snow plowing. Does anyone have any have any photographs of how the OEM plow hooks up? I have had no luck finding any such images on the net, and am looking for ideas.
Haven't seen one myself but is there a way you can tap into the front wheel axle hub as a mounting point by putting in a plate and longer bolts followed by an arm that extends out and a pivot point ? (Does that make sense or only to my warped mind ????)
Other than that you'd have to get access to the frame ahead of the front axles
not sure how the oem mounts , but a buddy has a homebuilt blade and it mounts a smalll arm to the front axle flange bolts as Paquette stated, seems like a reasonable and logical place to mount it to me .
PERFECT!!!!!! Thanks so much guys. That's EXACTLY what I needed. It looks like I can fabricate most if not all of that. I need to get my welder out of mothballs.
