i need to make a engine cradle for my new motor thats going into my max ii. im shopping for metal and am looking for input. what metal should i use? mild steel or chromoly. the no brainer is chromoly. i no what the difference is between the two metals but is chromoly necessary? the chassis appears to be mild steel so i dont see a problem using it other than weight constraints.
i figgured a .25thick mild steel plate would be ideal to mount my rotax. the engine is rubber mounted so i think this will good enough. wat do u think?
