Hi, i'm having a fuel issue.
94 vanguard 6x6, with a 16 briggs vanguard
My fuel is draining back into the tank when not in use.
this would be fine but it will not draw it up to the carb before the carb bowl empties. Then I have to spray staring fluid dirrectly into the carb continuously until the fuel makes it up to the carb.
I replaced my pulse pump, fuel lines, fuel filter, cleaned the tank and carb.
It seems to idle and run fine once the fuel gets to the carb. Although It does not like to hold WOT for long periods, It will sputter a bit and then take off again.
I was thinking it may be a defective fuel pump? Is there a was to test the output flow?
Also Is my filter suppost to be directional? so it will only flow one way?
