Heat build-up in engine area
Results 1 to 10 of 13
Thread: Heat build-up in engine area
    Aug 2011
    Kotzebue, Alaska
    1,209
    Hello. Our Avenger builds up a lot of heat in the engine compartment that I am not comfortable with. I keep thinking the heat might melt gas lines/filter and burn.
    The temp is averaging 170-180 degrees which isn't bad. It just that the heat builds up high that bothers me. Perhaps I'm being overly cautious, unnessesarily worried..to my question:
    Can I cut vent holes in the hood? How about holes in the firewall to add warmth to the driving area? Can I add another fan, perhaps mounted on the dash above the handle bar that plugs into the cigarrette lighter? Sounds fine but I value more experienced folks opinions than mine alone. Thanks.
    Nov 2009
    2,910
    How is your engine temp?
    The design is for the airflow to enter the right side, cool the radiator, and blow across the muffler on it's way out the left side. I would not cut any holes. You could try pulling the hood off and see how that cools it, but my guess is either the screen in front of the radiator is full of debris or your heat is normal.
    Texas
    2,161
    This is a perpetual problem for small engines. In my opinion these machines need expanded metal for hoods, the hot air will rise out and the cooler air can enter through the air ducts. The Max4s I've driven never overheat with the design they have. I have a tan Max2 with expanded over the top of the hood and it never overheats. The best solution is to go with water cooling, even then the heat has to get out.
    Argo came up with a optional hood exhaust fan to help remove heat from the engine compartment, part number 602-71.
    Aug 2011
    Kotzebue, Alaska
    1,209
    Thanks for the help guys. The engine temperture shows 170 degrees all day, except when traveling with the wind at which time it goes up to 180-185. It hasn't gotten more then this.
    I stop on occasion and pull the hood to cool the machine faster. Sometimes I feelhest blowing past the firewall edges and it concerns me a bit. I guess I' m acting paranoid about it.
    I rode the Argo s few times without the hood. It helps only a little, but dang the thing gets loud!
    The screen is clean, the fan works, the rotor blower works and the exhaust is clean. The temp averages 170 degrees so maybe all is well. I guess what I need is a "This is normal dude. Enjoy the ride. No worries."
    Aug 2011
    Kotzebue, Alaska
    1,209
    I just took a look at it. I would need to buy the scoop kit and the fan kit. They claim a fifty degree drop in temp. I would have to fork over three hundred dollars. This would make it to the very bottom of the to-buy list.
    Thank you for bringng it to my attention though.
    Nov 2009
    2,910
    Temperatures that seem very hot to us (humans), like 170 degrees, are not hot to mechanical items. Unless you are having a problem, I wouldn't worry about that temp.
    Remember the HDPE plastic wont melt till approx 500 degrees.
    Are all your exhaust shields in place, most of your heat is in the exhaust. As an example we had a JD mower with a carbed 25 hp. engine and after 10 minutes of full throttle with the deck engaged the manifold pipes were glowing red on into the mufler.
    You may want to check on richening up the engine to cool the exhaust some.
    Aug 2011
    Kotzebue, Alaska
    1,209
    Yes all parts are in their rightful place. I must be paranoid I guess. I do appreciate the help.
    Apr 2011
    Ontario Canada
    18
    Make sure your intake duct is tightly sealing against the air intake screen. If there are any gaps, hot air in the engine compartment will be recirculated over and over. If there is a gap ypu can rivet some rubber to the duct to close the gap.
