They then are invited up to Scampton to have a follow up session, which includes a taster drive in a rally Peugeot 205, the Argo cat and (in future) a rally Austin Mini as well.
We've had several successful outings in the machine of late. Getting its problems sorted out and it is now pretty reliable -always drives back from a foray under its own steam...
Tried to charge battery (flat at 11.43V) but several days on the solar charger didn't work so re-sited it in a less shady position.
All battery cells low on fluid so topped up -each cell took 15 shots from a tiny pipette to get up to the UPPER level line (measured by dopping a vernier in from the top casing).
Taped over the cells to stop more dirt getting in groove around each screw cap (1/2" deep socket to loosen battery clamp).
Replaced missing bolt on gear lever collar with a stainless one (bolt barely long enough to get the nut on though. There's still a tiny bit of play but used STUD N BEARING FIT by Loctite to hopefully take up the last bit of slack. Also tried a split pin but didn't have anything the right size. A Roofing bolt also fits!
Made a better stand to stop cover sagging under rain, but the cover has started to split now (UV degradation).
