i just decided im going to clean up my argo big time! im gonna take the top off clean all the crap out of the frame maybe painy it clean all sprokets and drive and so on!is this difficult and say if i run into trouble will i find someone who can help me?
Since the upper body is off you might want to straighten the square tubing under the seat that holds up the outer body shell. That will take care of your sag in the middle. It doesn't appear too bad but they have a bow.
when I rebuilt my I/C and the conquest,the machines were both stripped down to the bare nakedness.engine and frame out,everything washed and the frame painted.that way you can check all the bearings properly.also after you get it back together,you will know how to do a repair because you've taken it apart once and seen how everything works.
frame comes right out when the axles are all removed unless your skid plate is riveted to the frame .find my thread from a few years ago,all the pictures are there.
