+ Reply to Thread
Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 41 to 50 of 59
Thread: My attex 8x8 military trainer
  1. #41
    hydromike's Avatar
    hydromike is offline Attex Addict hydromike is on a distinguished road
    Join Date
    Jun 2007
    Location
    Buffalo, NY area
    Posts
    1,641
    Quote Originally Posted by marshgunner View Post
    I had some time today to start some welding, and thought it was going well. I welded a few of the cracks on the outside and then flipped the tub over and everything I welded broke apart. Crap!!!!
    Whenever I weld ABS, I find that I just about always have to weld both sides of a crack. It takes quite a bit of practice, and sometimes it's not pretty at all, but I lay the bead, and then use a heated up 1/2" wide prybar to sort of "mush" the entire bead and surrounding plastic together. I repeat the process on the opposite side of the crack, and it seems to hold up well. On my tank trainer, I have several cracks that have reappeared over the course of a couple of years of decent abuse, but they're mainly in the high-stress areas. Some of the cracks on your trainer likely aren't due to repeated stress, but rather impacts with something. You might get real good results in one area, and so-so results in others.
    Since I don't do a whole lot of plastic welding, I picked up a cheapie hot air welder. It's not a very elegant piece of equipment, but it gets the job done.
    EDIT:: Come to think of it, aside from the holes drilled in the dash on that upper, it was in pretty decent shape. You know, you could really break some new ground and just slice that yellow upper in half, and graft in the rails from your trainer, and add the requisite 4.5" from a third upper body.
  2. #42
    racerone3's Avatar
    racerone3 is offline Driver X racerone3 is on a distinguished road
    Join Date
    Oct 2007
    Location
    statesville, north carolina
    Posts
    1,947
    I will add my 2 cents here. Mike and I have had a TON of discussion on the topic of putting tanks back together, and I think we have used vastly different methods to get pretty similar results. He is using the hot air welder, I'm using the airless. He has never used ABS Goo... I use it like I use beer and peanut butter (AKA: too much)
    I will agree with what he said. YOU MUST WELD BOTH SIDES OF A CRACK to get any strength. I drilled holes and used stainless wire to lace together all the cracks in my tank, then welded both sides. on top of that i did a few layers of a glass/ goo hybred. Fiberglass cloth with really thin ABS GOO instead of resin. I'm only 3-4 months out, but no cracks have opened back up... with the exception of where my brother in law rammed the LR corner with a Pimpfoot
    For a nice ARMY/ Baby Sh^t green mix of ABS goo, use a lot of yellow, and a little Black. Black ABS pipe from a hardware store is a great source of raw plastic to melt down.
    this is the welder I'm using : Urethane Supply 5600HT Model 6 Airless Plastic Welder | eBay
    I get my welding rod from ABS Welding Rod | U.S. Plastic Corp.
  3. #43
    marshgunner is offline 6x6 World Sponsor marshgunner is on a distinguished road
    Join Date
    Apr 2011
    Location
    Fremont, Nebraska
    Posts
    102
    Well I have not done any work on the trainer for a few months now, but I hope to soon,either that or let someone else have some fun with it.
  4. #44
    jpswift1's Avatar
    jpswift1 is offline 6x6 World Sponsor jpswift1 is on a distinguished road
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    3,627
    Bring it back to life, Marshgunner! I was so excited when I saw this post to this old thread.
  5. #45
    hydromike's Avatar
    Join Date
    Jun 2007
    Location
    Buffalo, NY area
    Posts
    1,641
    ...either that or let someone else have some fun with it.
    Really? It'd certainly be a really big effort to get the 'ol girl back together, and I don't know how many people would want to try it. I mean, **I'd** try it. It's a big worse for wear than 5 was when I got her, but it's really just a matter of spending time to get it back into two big green pieces. Lots and lots and lots of ABS rod and goo.
    We only know of about half-a-dozen or so that are out there, so I hope this one can be saved..... Worse comes to worse, I have a bay open in the ABS ICU.
  6. #46
    LarryW's Avatar
    LarryW is offline Attex owner LarryW is on a distinguished road
    Join Date
    Jan 2008
    Location
    Michigan
    Posts
    3,235
    Oh man you can do it! You have great advise here. Give it a whirl!
    Race, thanks for posting the tip on the yellow and little black abs for a similar color. Good idea! That back right corner of mine was cracked and it did get bigger.
  7. #47
    Duck89's Avatar
    Duck89 is offline 6x6 World Sponsor Duck89 is on a distinguished road
    Join Date
    Jun 2011
    Location
    Orleans County, New York State
    Posts
    183
    Stick with it marshgunner! With some determination combined with the advise from the knowledgeable people on this site, you can do it no problem! You don't see a lot of those tank trainers around it seems, so you have something unique. Good luck!
    #1 Attex ST/300/D - "The Duck." Family owned since the early 1970's
    #2 Attex ST/300/D - Resto/Mod project
    "Answer the call of the wild, in an Attex"
  8. #48
    smooth_oakislander's Avatar
    smooth_oakislander is offline Registered Rider smooth_oakislander is on a distinguished road
    Join Date
    Mar 2008
    Location
    coastal ,NC
    Posts
    20
    Looks like a nice project you have there keep us posted how its going.
  9. #49
    Join Date
    Apr 2011
    Location
    Fremont, Nebraska
    Posts
    102
    Hey thanks guys for the pep talk on getting to work on it. I really did not want to get rid of it but after seeing it sit for a few months I just lost some intrested in it. But if I do let it go I will keep everyone in mind.
  10. #50
    Join Date
    Apr 2011
    Location
    Fremont, Nebraska
    Posts
    102
    I was staring at the rear damage of the trainer today and trying to think out how to repair it and noticed that their is a mold line on the back half of the tub. So I was thinking if I could find a useable lower tub I could cut along the mold line and use from the back two axles rearward and use the good tub section to replace the back half of the trainer. I have not looked at a 6 wheeler tub to see if the mold line is in one of those to.
    My collection: 4) attexes, 3) hustlers, 1) chapperal, and 1) crocodile Now I just need more room.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
