Have any of you ever used a polyurethane motor mount for your ATV? I am getting a lot of flex from the mounts in Jennifer's mid-engine Max IV and since I do not know the shear properties of the stock rubber vibration isolators that I am currently using from Recreatives Industries, I was hoping switching to a poly isolator would be an easy way to stiffen things up. I haven't had any luck finding a poly mount that is the same size though, or at least something close to the same size as our stock mounts?
The other option would be to find the stiffest rubber mount I could. Got any suggestions or even better, links?
This place had a ton of cylindrical vibration mounts: Square Cylindrical Vibration Mounts Rubber Neoprene Urethane Sorbothane Silicone Gel Ring Mounts Stud Nut Type but I really don't have any base properties of the stock max mount to compare them to.
Yea, I was TOO into it), and that is the true hardness test.
. I hope
Then i will have access to drill presses ,lathes. plastic welders. plastic formers, I need to get a piece of abs and get some abs flange rings made
for the outside bearings
