I have always liked the way the lil-trucks looked, and wanted one for quite some time....
Well, last summer at Ashtabula I finally got one. More like a body and a bunch of pieces of one, but still, it was a lil-truck.
All the axles had been cut and parts were missing so I decided to give it a good upgrade.
The original tires, I suspect were 21", had been rubbing the tub, probably due to body sag. This thing was in serious need of some TLC.
My goal here is for 26" tires with Adair tracks over them. That was my original goal with building the MaxII bigfoot ( http://www.6x6world.com/forums/max-a...-tall-tub.html ) but with the 40hp motor and not changing the gear ratio I think it is just too fast for tracks...... For the Lil-truck I took a MaxII and stretched the frame. I used an uncut lower tub to put the holes where I wanted and epoxied it to the Attex lower. I had to add about 8" in length (bigger truck bed) and 1 1/2" in width at the rear. The maxII frame is 1" wider than the Attex and I wanted to be able to get the frame in and out. I'm keeping the original 18hp Briggs motor, but gearing it down a little. The maxII jackshaft has a 22t sprocket paired to a 22t on the center axle. I replaced the jackshaft sprocket with a 15 tooth. By my calculations, with a 26" tire I should have the ground speed of a MaxIV with the little 21" tires.....so, just a little faster than a typical Argo in hi gear. Hopefully this will make for a perfect trail machine.
Here is my progress so far[IMG]http://www.6x6world.com/gallery/data.../IMG_02291.JPG[/IMG]
Link to the gallery: http://www.6x6world.com/gallery/g116...ter-truck.html
