what to do about the plastic skid plate on my scrambler
Results 1 to 5 of 5
Thread: what to do about the plastic skid plate on my scrambler
    the plastic skid plate on the bottom of my scrambler has seen better days. so can i just take it off. or is there some thing else that i can do. also if i get rid of the skid plate what is the best way to fill all the rivit holes that held it on. bruce dye
    Jan 2008
    Vicksburg, Michigan
    3,508
    Quote Originally Posted by brucemdye View Post
    My skid plate was also pretty much junk too. That plastic get real fragile with age. I tore mine off. The new ones didnt have it and the lower end seems alot thinner on them. They did have a u channel piece of metal that was under the machine, though.
    I haven't filled my holes yet but I think I was going to probably just put rivets back in. Make sure its a good grade marine rivet though. You could also use some sort of paint-able epoxy or any sort of body filler.
    u channel ? did that just run under the lowest spots like where the gears are at. the other thing is under then the axels i have not found any other rubber seals or silacone or thing to water proof it.
    sorry i just looked at your pictures of the channel thanks for the help on that
    bruce
    Aug 2007
    Fargo ND
    135
    I would go with larry on the holes and use marine grade pop rivets that seems like the most durable way to go about it
    1969 Gip-Sea four stroke conversion 1983 honda Big Red 200E engine
