2000 Max II, I know some of you all have made UHMW bearing extensions for your machines, How are they holding up? did you do away with the outer bearings's completely and just use the UHWM? looking at buying tracks for my MAX and will need bearing extensions, Already have 3 inch offset wheels so I should be good on that..the tracks I am looking at are the factory plastic segmented ones, Used and around 400 dollars.
